more bang for the bucks #577260 03/07/05 10:00 PM
slick8up Offline OP
i got a 1994 yj with 2.5 5 speed with 33/12.50s new gears on the way i went with 4.56s was doing so reading on the past posts seen alot of stuff about the tb spacers will this be a good way to go to get a little more power and wheres the best place to get one at "and did i read that you can 4.o spacer on a 2.5 for a little more power thanks steve <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
94 jeep 3.5 lift 4.56s gears 33/12.5s geolanders mt locked rear warn 8000 and a 4 banger 4 power
Re: more bang for the bucks [Re: slick8up] #577261 03/07/05 10:22 PM
BigJim Offline
What is it that would make you even THINK that another 1 or even 2 inches would make any difference? How easy would it have been for MOPAR to have put the extra distance in there in the first place? Why didn't they?
The answer to your queation is an emphatic hell no! Leave the well designed intake alone and get some 5:12 gears or some new seatcovers with your money..
If you want more power purchase a Jeep with the 6 cyl in it..
Big JIm
Re: more bang for the bucks [Re: BigJim] #577262 03/08/05 12:47 AM
Alot of the performance mods on the market are gimmics. Take the TB spacer for an example. The theory behind a spacer on the TB is tune the harmonic reasonance of the intake system so that a positive pressure pulse hits the back of the intake valve just as it is closing to force jsut a bit more air into the cylinders. You ever look at the engine on an indycar? notice how the intact manifold looks like a wierd maze with stuff jutting out the top? That is a good example of near perfect intake tuning. Another good example of intake tuning is edlebroke intake manifolds for big V-8's. If you change the arc the air takes or the length of the runner or the chamber volume you can make them work really well through certain RPM's. TB spacers don't work for 2 reasons; 1, they don't change the volume or the runner length by a significant amount, 2, they are in the wrong place to change the harmonics. Because they are at pretty much a 90 degree angle to the pressure pulses coming off the intake, they have little or no effect. Instead of the pressure pulse bouncing off the back side of the TB, they bounce off the opposite side of the intake manifold.
Most of the bolt on cheap mods are like this. Unless you fork out the cash for a mod the really works (IE Header, new ported head, camshaft, etc...) you end up changine the sound of the engine without making any significant power. Run us buy a budget and ideas you have, there is a reason why it costs alot of money for an engine that makes lots of power.....
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5909 MB (Peak: 0.6458 MB) Data Comp: Off Server Time: 2026-06-10 04:14:44 UTC
