#1 The A/C does not engage at all. The compressor turns over freely enough, but the clutch will not engage. Fuses all check out, no creative wiring from the prior owner, everything looks like it is in the right place, but it just won't hook up. I'm going to do some testing for power just to make sure the clutch isn't stuck or just not work, but I suspect I'll find that it just isn't getting power. It has been neglected for some years, so I assume the system needs to be recharged. So my question would be is there a cut off that keeps it from running when there isn't enough of a charge of freon in the system? I couldn't pick something like that out for sure in the wiring diagram, so I thought I'd ask if anyone has experience/ideas on the subject.
Yes, there is a pressure switch that will kill the compressor if there isn't enough pressure in the system.
Also the thermostat may be bad. More likely the first is your problem.
#2 The defroster door will not move at all. I tested the vac switch/solenoid deal that is in behind the glovebox and it is getting power at the right time and the vac diaphram on the other end is functional, no leaks there. My other 86 doesn't have A/C, and the setup is completely different. The defroster door is 100% mechanical, so I don't have spare parts to try swapping in and out troubleshooting. I've gone over the factory manual. but it doesn't really explain much on how this vac system works, for example where does the vac come from? Could this be related to the A/C not being functional? Any tips or ideas on how to troubleshoot this further would be a help. I have not had a lot of time to work on it, but I will have a lot more time in a couple weeks so I'd like to come at it with as many ideas as I can find.
Make sure the vacuum like is hooked up at the firewall and is bring vacuum to the solinoid. There's a little nipple sticking out right were the two A/C lines enter the firewall. That nipple should have a vacuum line attached to it. If it does and there is vacuum present, then try swapping the two hoses that go to that solinoid under the dash. They will only work in one direction and if the hoses get swapped, the vacuum operated doors won't work.
