5spd Swap ?'s - Reverse lights & 4WD indicator #578293 03/09/05 09:02 PM
Runningman Offline OP
I swapped a W56 into my 85 4runner a few month ago w/ no problems, but never got around to connecting my backup lights or 4WD indicator in the dash.
Can anyone point me in the right direction on where to splice the wires coming off the tranny?
85 Toyota 4runner with some stuff...
[color:"blue"]Trail Pics[/color]
Re: 5spd Swap ?'s - Reverse lights & 4WD indicator [Re: Runningman] #578294 03/09/05 10:06 PM
4Crawler Offline
Reserse switch is in the tranny, driver's side near the fill plug. 4WD switch is in the t-case, passenger side near the speedo cable.
Re: 5spd Swap ?'s - Reverse lights & 4WD indicator [Re: 4Crawler] #578295 03/09/05 10:11 PM
I should've been more clear. I know what the wires coming off the t-case and tranny are for. I just don't know where to tie them in.
Re: 5spd Swap ?'s - Reverse lights & 4WD indicator [Re: Runningman] #578296 03/09/05 10:48 PM
Runner-Man Offline
Isn't there a few 'extra' wires under the hood from the tranny and transfer case you removed? Those wires should have been there for the tranny and transfer case you took out.
Re: 5spd Swap ?'s - Reverse lights & 4WD indicator [Re: Runningman] #578297 03/10/05 03:40 AM
ToyinAround Offline
Did you do a Auto to 5-speed swap? If so then this might help, Its someone elses post that i copied and kept. I still haven't tried to hook mine up and its been about 4 years <img src="/forums/images/graemlins/scared.gif" alt="" />
The difficulty came with the wiring.
The plugs are INCOMPATABLE.
Try to get the plugs from the donor that hook up the reverse lights and ADD.
There is a big white plug that plugged into the automatic.
It contains the Neutral Safety Switch and reverse light wires.
I tapped the Neutral Safety Switch into the bottom clutch pedal sensor so I have to push in the clutch in fully in order to start.
If you just connect the wires and leave it, the cruise control won't work because it thinks you have put the car in Neutral or
Park and left it there.
Also, I tapped the wires from the brake light switch into the top switch of the clutch pedal so the cruise control disengages if
I put in the clutch.
If you don't have cruise control, don't worry. In the reverse light wires are in the white plug too. They must be cut off and
wired directly to the switch on the 5-Speed found on the passenger's side.
The ADD Switch, if you have it, wires into the top switch in the back top of the transfer case. There are a lot more wires left,
but none are needed since the automatic is gone.
Try to cap them and tuck them away or remove them. I just tucked mine away. I also left the automatic ECU in the center console.
1987 4Runner SR5,SAS,6 inches of lift,35in BFG's,Welded Front,Detroit E-Z locker V-6 Rear, 5.29's
Re: 5spd Swap ?'s - Reverse lights & 4WD indicator [Re: Runningman] #578298 03/10/05 05:13 AM
4Crawler Offline
Re: 5spd Swap ?'s - Reverse lights & 4WD indicator [Re: 4Crawler] #578299 03/10/05 05:37 AM
Yes, I did the auto to 5spd swap. I have the FSM and didn't even think about it <img src="/forums/images/graemlins/rolleyes.gif" alt="" />. Now I know what color wires to look for. I did have a lot of unused plugs left over after removing the auto, I'll look there first. I'll post up when I get it all worked out. Thanks.
Re: 5spd Swap ?'s - Reverse lights & 4WD indicator [Re: Runningman] #578300 03/14/05 09:33 PM
I got the wiring hooked up yesterday and I now have working backup lights along with a functional 4WD indicator <img src="/forums/images/graemlins/kewl.gif" alt="" />.
I have an 85 4runner, however, the wiring is supposed to be similar on trucks and 4runners up to 1994 (according to Haynes <img src="/forums/images/graemlins/cyclops.gif" alt="" />).
I made all of the new connections underneath the intake manifold. This is where you have all of those unused wires & plugs after removing the auto tranny.
The 4WD indicator switch on the T-case just needs a single wire connection. You need to splice into a small, light green wire. It runs into a small, white, round plug that shares 2 other small wires.
The backup light switch on the tranny uses 2 wires, so you have to find 2 wires to splice into;
One of them is a small, red wire w/blue stripe. It runs into the same plug that the neutral start switch wiring runs into. It's a large, round, tan plug.
The other one is a small, solid red wire. It runs into a large, round, white plug that shares two other small wires.
I had to solder in extra wire at the manifold and routed it to the tranny. I used standard, pre-insulated, crimp-on, quick-disconnects to hook up the wiring at the tranny.
ThatÆs it.
Re: 5spd Swap ?'s - Reverse lights & 4WD indicator [Re: Runningman] #578301 04/26/05 12:20 AM
swamprunner Offline
Runningman,
Your post just saved me a massive amount of decifering of wires. Just swapped in my 3rd 5spd...figured I'd hook up the backup lights since I finally got the tranny that I wanted in the truck (r151f). Thanks for the details on the wires...I owe you a few <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
85 SR5 4runner....Too many hours of work put into it, Hacked, Beaten, and Still running after all I've put it through
87 Turbo Pickup...Bought Her for $500 put another $500 in her and she's running like a dream.
Re: 5spd Swap ?'s - Reverse lights & 4WD indicator [Re: swamprunner] #578302 04/27/05 05:03 PM
Great! I'm glad it was helpful to you.
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.012s) Memory: 0.6372 MB (Peak: 0.7472 MB) Data Comp: Off Server Time: 2026-11-19 05:34:16 UTC
