Should I use the V6 rear axle that's lying around? #578447 03/10/05 03:11 AM
BrokeAsAJoke Offline OP
I won't get any real work done until after tax season (I'm an accountant for now <img src="/forums/images/graemlins/barf.gif" alt="" /> ), but I'm collecting parts here and there for a build-up on my 84 this spring. My uncle is going to teach me how to bend pipe and weld. <img src="/forums/images/graemlins/smile.gif" alt="" />
All I have so far is rebuilt hubs, ac compressor for onboard air, 33's, 15x8's and IFS front calipers. The vented landcuiser rotors seem pricey at the parts store. What has everyone had to shell out for them? I know building a rig isn't cheap, but I don't want to pay more than I have to.
My donor is an 88 4runner (V6 Auto, 4.10 gears <img src="/forums/images/graemlins/frown.gif" alt="" /> ). Should I use the rear axle from it? (I need to decide before ordering gears and lockers) Is there anything that would prevent me from moving the hangers forward far enough to reduce the wheelbase to that of a regular cab and double bobbing the bed?
I'm planning on using chevy springs in the rear and yota rears in the front. Will I be able to make satisfactory front spring packs using only toyota leaves from the 84 and 88?
I believe I have a G52 transmission and whatever transfer case goes with it. What transfer cases will work for a dual case setup? I can score an 83 transfer case for some parts off my donor.
I'm hating the carb, so I'll probably swap in injection from a 2wd donor. (I'm waiting for my friend to retire his 93 with 320k on it)
Any other parts I can use from the 88?
Also, can someone recommend a site to host pics?
Thanks in advance and for all the advice you have already given on the board. <img src="/forums/images/graemlins/smile.gif" alt="" />
88 Reg Cab 22RE 5spd, Mods: 94 bed, Sunroof, Bucket Seats, PW, PL, AC, Keyless entry, remote start. (Practically a Lexus)
Re: Should I use the V6 rear axle that's lying around? [Re: BrokeAsAJoke] #578448 03/10/05 03:20 AM
kewlynx Offline
Check the Toyota FAQ here for tranny info. Your xfer case questions can be explored over at marlincrawler.com; he can set you up nicely. Bit of a start anyway. Might check the axle lengths and see what needs compensated.
Quite a bob you plan on; might take another look at your fuel tank situation.
Some of the other modded guys will chime in, I'm sure.
www.photobucket.com
**ubi apis- ibi salus**
Re: Should I use the V6 rear axle that's lying around? [Re: BrokeAsAJoke] #578449 03/10/05 03:46 AM
matts Offline
The rear axle on the donor vehicle is probably a keeper. It's 3 inches wider than your '84 axle and probably has a beefier housing and differential for the V6. Because it's behind an automatic it may have 4.30 gears though, which you will want to change out for at least 4.56 or 4.88 gears, and your front differential will need to have matching gears in any case. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5926 MB (Peak: 0.6477 MB) Data Comp: Off Server Time: 2026-06-20 22:17:56 UTC
