Vehicle Stability Control (VSC) Warning Lights #578631 03/10/05 06:11 AM
rodeo_chris Offline OP
I just took my '04 4Runner (SR5 4WD V6 4-spd auto) in for it's first annual North Carolina emissions/safety inspection, which requires an analyzer hook-up. While there, I also asked them to rotate the tires. When I picked it up, there were two warning messages on the dash just to the left of the gear indicator. Why are the "VSC TRAC" and "VSC OFF" lights on and how do I turn them off? We know it stands for Vehicle Stability Control, but no one at the repair shop knows what do to and we're stumped? Besides being visually annoying, I'd like for the messages to only be on when they're supposed to be. Help! lol
94 Rodeo, 35's, 5.38's, locked F&R, Rocker bar on one side, other side in garage
96 Tacoma, DD, pre-dented
Re: Vehicle Stability Control (VSC) Warning Lights [Re: rodeo_chris] #578632 03/10/05 07:36 AM
kewlynx Offline
Got an owner's manual for that thing?
Only thing I can think of is they induced the error.
**ubi apis- ibi salus**
Re: Vehicle Stability Control (VSC) Warning Lights [Re: kewlynx] #578633 03/10/05 03:01 PM
kewlynx-
Yes, I've got all owner manuals, but they're written someone vaguely. In no place do I see "this is why they're on" and "this is where/how you turn them off." I'm pretty sure the VSC warnings were induced when the inspection/ emissions analyzer was hooked up or when they jacked it up to rotate the tires, but they have "washed their hands" of the matter. The tires have tire inflation sensors that transmit to the central computer - not sure if that influences anything wither. Wish I could figure this out without taking it to the dealer.
Thanks for anything you can recommend.
Re: Vehicle Stability Control (VSC) Warning Lights [Re: rodeo_chris] #578634 03/10/05 03:35 PM
JohnJerk Offline
Aren't you still under warranty?
Many off roaders have been wishing for what happened to you. Your tire rotator might see an increase in business. <img src="/forums/images/graemlins/lol.gif" alt="" /> Mostly kidding.
2006 Tacoma Crew Cab 4x4 Auto TRD Off Road
2002 4runner SR5 4x4 79K miles (Sold)
1993 Pickup Ext. Cab 22RE 4x4 82K miles (Sold)
Park City, Utah
Re: Vehicle Stability Control (VSC) Warning Lights [Re: rodeo_chris] #578635 03/10/05 06:21 PM
I've got the answer for you!! I recently had to go through the same thing. After 4 different trips, new computer system, etc, the dealership finally figured it out. They changed the thermostat even though it seemed fine. They said that "they realized it was 5 - 10 degrees off and it was enough to keep it open." Or something like that. Regardless, it actually did fix the problem and I noticed that the runner now runs a temperature exactly in the middle rather than cool like it did before. I don't know if this info will help, but hopefully it's a start for you.
Re: Vehicle Stability Control (VSC) Warning Lights [Re: rodeo_chris] #578636 03/11/05 02:59 AM
kewlynx Offline
I went over to ALL DATA and pulled up your TSB list. You might want to print that out and take it to the dealer and tell them you want to read up on a couple of them that seem to be pertinent to this. If they give you a runaround, I think you can get the TSB info from All Data's site for a small fee.
Hope that helps as well. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Vehicle Stability Control (VSC) Warning Lights [Re: JohnJerk] #578637 03/11/05 05:43 AM
John Jerk -
That's a thought (warranty). March 19 will make a year since it was purchased and it's got 26k miles and some change. What is the warranty allowance on a new 4Runner, btw?
Thanks
Re: Vehicle Stability Control (VSC) Warning Lights #578638 03/11/05 05:47 AM
back to future -
Thanks for your reply. Would a new thermostat affect the "VSC TRAC" and "VSC OFF" warning lights, which are the ones I have? VSC stands for Vehicle Stability Control and I'm not sure how that's tied to the cooling system? Are these the warning messages you also had?
Thanks
Re: Vehicle Stability Control (VSC) Warning Lights [Re: kewlynx] #578639 03/11/05 05:50 AM
kewlynx -
I'll try ALL DATA and the TSB's. Maybe there's a bulletin I can use. Hope so!
Thanks
Re: Vehicle Stability Control (VSC) Warning Lights [Re: rodeo_chris] #578640 03/11/05 08:19 AM
Jeff the marmot Offline
Just a guess, but I'd blame it on the tire rotation. VSC is very similar to ABS in that it compares the rotating speeds of each tire constantly. If you have some weird wear going on with any of your tires, it can throw off the "size" of just some of the tires. There's some very small percentage tolerance that's OK for the computer. But it's possible that it gradually "learns" a new tolerance for worn tires if you ease into it with many miles between tire rotations. Outside that range and it'll turn on a warning light for ABS or VSC. That's happened to me once after changing a tire on my 3rd gen with the ABS light. Actually, I'd expect it to do the same warning for ABS, so that's just as much reason that what I'm suggesting here isn't the case for your problem. If it is, compare tire wear between all the tires, check air pressure, and crawl around and make sure the shop didn't do something stupid like pulling out or damaging one of the wheel speed sensors when they rotated your tires. Try briefly disconnecting the battery if restarting it a few times doesn't reset it.
Also, is there a way to easily disable VSC for '04's? If so, maybe they know about it and did that prior to their test.
The thermostat comment seems like it was intended for a different thread.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
PHP: 7.4.33 Page Time: 0.020s Queries: 16 (0.015s) Memory: 0.6432 MB (Peak: 0.7663 MB) Data Comp: Off Server Time: 2026-11-16 08:43:01 UTC
