Looking for input on this please.
Ahh. My trials and tribulations?
I decided I wanted to finally get that Amigo/Sport I'd wanted for the last decade about two years ago. I went hunting, and had to decide between a used 98 softtop 5speed with 36K on the odometer, or a new leftover 02 hardtop auto with only 2k in dealer rep miles.
Both were 4WD, V6 3.2L, alloy wheels, yaddda yeaddda.
I opted for the 02, since it had longer warranty, all the creature comforts (factory alarm, power everything, etc) and less miles so I wouldn't be paranoid about how the motor was treated during break-in. (I have a firm belief break-in is really what determines how the motor will live out it's life; but that's me. Then again, my motor carefully broken in doesn't eat oil like most other Zu's at the same rate, I only lose about a HALF quart every three to four THOUSAND miles)
I digress.
Things to be conscious of;
For anyting other than street use, the V6 3.2L is really a must have. Even though it's a SWB, the sport is a heavy little truck. (slightly
under 4k lbs; *corrected after I looked it up) I get a consistent 20-21 mpg, if I'm not romping on the pedal. (in your daugters case, better to under power the 2WD so that she doesn't speed demon herself into trouble; a SWB is as always prone to tipping at high speed in a corner)
Reliability; see comment about break in, but for the most part, the handful of MAJOR/Catastrophic Zu issues you see on this forum are rare; they are usually stress induced by the owner. (beat the snot of the truck while wheeling it across 3 foot boulders and 4 foot deep mud bogs) The LARGE majority of the rest that occur are preventable through normal maintenance.
Someone else had said it, and I can't agree more; these are not 'turn key and drive forever' vehicles. (like say, a Honda or Toyota) Maintenance at the required periodic intervals is VERY IMPORTANT to making sure things last a long time.
With that maintenance, I've heard, and seen Zu's break the 150k mile mark without a sweat.
Caveats:
If you plan on lifting or wheeling the truck, from Jan 2002 (just my luck) and on, the forward hubs on the 4WD model were changed to a new design, that removes any sort of locking hub mechanism.
In it's place, is a 'single hub' that is bound to the front half shaft (CV axle) directly via a large nut, much like AWD cars. This means that you can NEVER disengage the front CV's and prevent their rotation. (like you could if you had manual locking hubs installed)
When lifted, the higher angles of the CV joint stress the CV joint boot, and thus, you 'may' wear them out more if they're constantly rotating.
I say 'may' because some people do it (lift and let it rotate) anyhow and get a year or more out of the boots without any problems.
Also, although I have not experienced it, there was a supposed design flaw that's been discussed in the driveline, where a slip joint is not easily greaseable, and not on the list of items during normal maintenance. If allowed to degrease (through water and wear) the slip joint in the driveshaft causes a 'pop' noise on startup of motion. This was supposedly addressed in 04, but no one I know of has confirmed this; I believe I read that the usual solution is to have a driveshaft shop fab up a one piece unit to replace the factory two piece slipjointed version, thereby removing the slipjoint and the noise.
Lastly, I haven't experienced it yet personally, since mine is still relatively 'new', but eventually the alternator will fail. (or the owner will kill it because it's mounted so low in the engine bay that driving through 3 feet of water nukes it) It's an EXPENSIVE part, with no real alternative aftermarket units. I've heard of 400+ dollar replacement costs on that item ALONE. For that reason, I opted for a thousand dollar extended bumper to bumper warranty since I figured inside of 10 years, It'll go at least once, and I'll recoup most of my money right then and there.
Otherwise, all the normal car buying advice is status quo.
I will say that I've been on half a dozen auto enthusiast forums and of all of them, this one is far and above the best community I have found; the members genuinely care about each other, help each other out all the time, give each other fair pricing on all parts to each other back and forth CONSISTENTLY, and are the most reserved tongued group of fellows and gals I've seen when someone posts a request for searchable information. I think having a community like this goes a LONG way towards enjoying your car any time you have a curiousity or question about it.
Add to that my Sport has been an absolute joy to drive for the last 2 years, and it's no wonder I'm happy to write this VERY LONG 'smiley'ish length post for you. LMAO.
Anyhow, thats all I have to offer right now; if you have questions, feel free to fire away....
E.
