99 amigo body lift? where to find one? #579094 03/11/05 07:20 PM
TrooperII Offline OP
I just bought some 31x10.50x15's and want to put them on my new amigo. I cranked up the torsion bars and the front still hit alittle in sharpe turns. I did'nt realize that the rear was coil springs untill after i bought the tires. So any suggestions? I have been looking for a body kit on the web and have only found them for 89-94 Amigos.
85 2.3 Woods Trooper (bye bye 1.9)
89 2.6 RS (really short)x2
94 Amigo
86 Troopers x2
Its really an addiction
Re: 99 amigo body lift? where to find one? [Re: TrooperII] #579095 03/11/05 07:39 PM
A suspension lift might be the way to go.
Just swap out the coil springs and crank up the front.
Do a search for details.
Steve
Re: 99 amigo body lift? where to find one? [Re: TrooperII] #579096 03/11/05 10:15 PM
Bigpoppax2 Offline
Check out the lifts on:
www.darlington-offroad.com
www.independent4x.com
They have some good customer service, and their parts are good quality.
Joe
Re: 99 amigo body lift? where to find one? [Re: TrooperII] #579097 03/11/05 10:19 PM
HCMP Offline
I did one using the 1st gen body lift kit. You'll end up with 2 extra pucks left over.
--jeremy
Re: 99 amigo body lift? where to find one? [Re: TrooperII] #579098 03/12/05 07:40 AM
Bansil Offline
You definitly need to trim your fenders...it's not noticable after it's done.......click here for black-ops fender trim fender trim
My .02 -
I would lift the suspension first and then if you really want it do the B/L........with a suspension lift,it will make a big difference in the handling of your amigo.And it will give you more ground clearance under the truck....unlike a B/L witch will only raise the body and then give you more stuff to cover-up and cut-off so it looks better......
Bansil
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: 99 amigo body lift? where to find one? [Re: Bansil] #579099 03/15/05 04:12 AM
Z
ZooMigo Offline
It's a REALLY old writeup, but I figured out how to do a BL on a 2Gen back in '00. Check out my writeup here.
http://zoomigo.50megs.com/mod_bodylift.htm
Kevin
White '99 5Speed Softie. Some extra custom junk. - RIP
Stock Pink 92 2WD Amigo : Flamigo smile
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6104 MB (Peak: 0.6801 MB) Data Comp: Off Server Time: 2026-11-03 19:32:31 UTC
