YJ body lift #580445 03/15/05 07:03 AM
4x4david Offline OP
I would like to put a body lift on my 89 yj. What is the max body lift I can go without affecting things?
Getting the Wheeling fever...
4x4david
Re: YJ body lift [Re: 4x4david] #580446 03/15/05 07:19 AM
TX4wl Offline
don't go for a 3" <<thats the bigest>>>.............2" will work and you can stuff 33's for street use ... get the hang of the jeep then upgrade <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: YJ body lift [Re: TX4wl] #580447 03/15/05 07:22 AM
TX4wl Offline
by upgrade i mean..... get the hang of your new lift... then take it off then do a real one .... jeepin is not cheap.. but a body lift id not a bad way to start... but toss it when you get a real lift ... your tub will thank you for it <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: YJ body lift [Re: TX4wl] #580448 03/15/05 04:35 PM
NCBBA2358 Offline
Two inch body lift will pick you up, but you will still be limited. If this is a money issue, then it will most likely work out for you and require minimum hours of modifying things and busting knuckles.
A 2-3 inch suspension lift is a better way to go, you will be able to lower your axles and have all the adjustments of your suspension done at once and the body will remain intact and not have the stress of the body lift.
What exactly are you trying to do/get out of a lift?
I've seen an 8 inch suspension lift under a 4 inch body lift with tractor tires.... The guy that did it just wanted to look cool, flipped his Jeep and rolled it down a mountain, totaled it, no insurance and out of money from making his rig "look snazzy", now he drives an old beat up ford ranger from the early 80's and hates it.
Lets take a look at what exactly are you trying to do/get out of a lift?
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
Re: YJ body lift [Re: NCBBA2358] #580449 03/16/05 03:43 AM
fishtaker Offline
Wouldn't be Big Jim would it? <img src="/forums/images/graemlins/nana.gif" alt="" />
03 TJ 5 Speed I-6 30X9.50 BFG KO's
Re: YJ body lift [Re: 4x4david] #580450 03/17/05 12:22 AM
I have an 89 YJ without a lift cause its my daily driver. I am still able to put 31's under her and lifted it about 2 inches from factory tires. If it is a $$ issue I would wait till you had the $$ to do a proper lift it would be well worth the wait.
Re: YJ body lift #580451 03/17/05 05:34 PM
mskelly, so you have 31x10.5's on a stock(?) yj? did it work for you without rub, or did you have to mod anything?
that's what i'm hoping to do with my stock '93 yj, keeping it on road only for now, until i can lift the suspension sometime this summer.
Re: YJ body lift #580452 03/18/05 05:41 AM
I too ran 31x10.5 on stock suspension (even 32x11.5 for a time) and only minor rubbing of the spring on a full lock turn and minor rubbing of the platic fender trim.
Re: YJ body lift #580453 03/18/05 03:55 PM
NCBBA2358 Offline
Fishtaker, not this time!
mskelly, do you have new springs? If I had tried to put 31's on my 91 YJ last year without new springs, the tires would hit the fenders! The bigger tires will surely add to the lift and clearance of the Jeep, but the clearance issue comes into play.... My daily driver is also my Jeep most of the time. I was thrilled to have the bones to put the 2.5 inch lift and a set of 31X10.50 spurs under there and it "looks" great and handles quite well. I don't do mountain hopping or swamp runs. Most of my trails have creeks to cross, a few rocky spots and lots of ruts and slick mud and plenty of steep angles and tight turns through the woods. This handles great on the road, on these logging "roads" as well as keeps the fuel bill down. Anything larger would kill me, anything smaller would look "cute"....
4x4david, If you want, you can put coil-over shocks on there or a slight body lift and get by with up to 31's without any trouble at all. You will more than likely want the spring lift pretty soon though. It may look a little silly for a little while, but I would put the money into a suspension lift first, then put the next batch of money in tires.....
kmoney, sure, you can do it, but you will most likely not have much clearance at all up in the fenders... You'd most likely have to be really careful when going over speed bumps and not be able to hit too many bumps or rocks or trees or whatever on a trail and surely not be able to hop the dunes....
sunder's about right, but the rubbing is damaging something that can be avoided... Just something to think about....
Putting the wider tires on will naturally be different than the stock sized tires.... Adjusting the bump stop will keep your tires from getting ground down by your springs. The hitting the flares/"plastic fender trim" won't be avoided unless you do something to get them higher or out of the way, like remove them, and then risk the tires sticking out past the fenders and getting a ticket in some states, or put a lift of some sort under it and get the trim up higher and away from the tires...
Summing up a bit, You really will have to consider what you want to get out of your Jeep. If you just want something for riding on flat stuff, then you can get away with a little grinding noise.... If you want to get ground clearance to actually clear obsticles that are in your way of getting to a scenic spot way up a canyon or top of a mountain or down in a valley at a lake or wherever, you will need to consider putting a little adjustment in your altitude.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6240 MB (Peak: 0.7262 MB) Data Comp: Off Server Time: 2026-05-30 01:16:23 UTC
