Battery #580828 03/16/05 04:21 AM
jroc Offline OP
Would a dying batt make the horn go apechit all of a sudden? While I was inside sitting on the couch just 20 minutes ago my truck parked out in the drive decides to awaken the hood with both horns going full bore. WTF......it's raining and cool but damm. Noticed last week that my low (fog) beams on my Cibie's don't work........might have wiring problems but how could that effect the horns? I think my truck is turning into Christina............
Any ideas. Looks like a Optima will be going in soon.
Re: Battery [Re: jroc] #580829 03/16/05 06:53 AM
garym Offline
Shouldn't unless you have the auto lock doors with the alarm system. If it gets wet, like if you wife shampoos the vehicle's carpet and forgets about the alarm logic unit being under the seat, it does all kinds of fun things. Other then that it's just a simple circuit. Horn buttons provide a ground to the horn relay located in the driver's side kick panel. Relay sends 12 volts to the horns. Other side of the horn is ground. Could be the horn button in the steering wheel shorting to ground by itself or the wire to that button rubbing through and shorting out in the steering column.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Battery [Re: jroc] #580830 03/17/05 03:06 AM
dogslovetrucks Offline
You should definitely take it to the master techs at your dealer...
I will play the part for them
"it sounds like your transmission is shot, and you need a new fuel system."
I found that optima makes a battery with the posts reversed that fits VERY nicely into our engine compartment. I love mine, and I have pulled a bonehead leave the lights on for 2 hours, and was able to start up the truck and pull away.
Re: Battery [Re: dogslovetrucks] #580831 03/17/05 05:53 AM
jroc Offline OP
can't figure out what happened last night. I hooked the positive wire back up this morning and everything is fine. Truck started, horn quiet...my truck is acting strange lately.......
Re: Battery [Re: jroc] #580832 03/17/05 05:56 AM
4
4xGeek Offline
How long did that stealership have their hands on it? <img src="/forums/images/graemlins/lol.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Battery [Re: jroc] #580833 03/18/05 04:43 PM
garym Offline
Next time it happens, if it happens, find out before hand where you horn relay is and yank it while it is doing it. At least that will isolate the problem a bit. You could also go somewhere and hit the horn a bunch of times while turning the steering wheel to see if you can get it to happen again. I thing the stealership parking lot is a good spot. <img src="/forums/images/graemlins/lol.gif" alt="" />
02 Camry LE
2008 Yaris
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6069 MB (Peak: 0.6768 MB) Data Comp: Off Server Time: 2026-07-16 15:03:05 UTC
