Transmission problem #581111 03/16/05 09:08 PM
P
Postal Bill Offline OP
2001 4Runner automatic. Stopped running today. Engine will start and run fine till I shift into any gear. Then the engine will stop. Any thoughts or suggestions?
Growing OLD is mandatory
Growing UP is optional
2001 Tundra
2001 4 Runner
1984 Corvette
Re: Transmission problem [Re: Postal Bill] #581112 03/16/05 09:33 PM
If you try to give it a little gas while shifting will it stay running?
Re: Transmission problem #581113 03/16/05 09:35 PM
P
No, it quits no matter how fast the engine is running when you put it in gear.
2001 Tundra
2001 4 Runner
1984 Corvette
Re: Transmission problem [Re: Postal Bill] #581114 03/16/05 09:39 PM
Lockup solenoid may be stuck or the trans pump has siezed. Either way you are probably looking at a trip to the dealership. Do you hear any loud clicking when shifting?
Re: Transmission problem #581115 03/16/05 10:30 PM
P
It made a rough shift from 1st to 2nd when I first started out this morning, but that was all. Like a thump. 5 miles later it stopped while at a red light. I just had it towed to a local tranny shop. They will look at it tomorrow.
2001 Tundra
2001 4 Runner
1984 Corvette
Re: Transmission problem [Re: Postal Bill] #581116 03/17/05 04:40 AM
Let us know how this one turns out.
Re: Transmission problem #581117 03/23/05 02:50 PM
P
It took the tranny shop until yesterday to start checking it out. So far all solenoids seem to be OK and they are now going to pull the transmission. Suspect a broken pump?
2001 Tundra
2001 4 Runner
1984 Corvette
Re: Transmission problem [Re: Postal Bill] #581118 04/03/05 09:00 PM
P
FINALLY got it back on the road on Thursday. The problem was major. Transmission fluid cooler? was clogged (or failed) and fluid was not circulating. They had to rebuild the torque converter and transmission. Replace all clutches, o-rings, gaskets and seals. Replaced band and solenoids. They rebuilt the complete front of transmission, pump, overdrive section back to the center support. Now I'm broke. <img src="/forums/images/graemlins/angry.gif" alt="" />
2001 Tundra
2001 4 Runner
1984 Corvette
Re: Transmission problem [Re: Postal Bill] #581119 04/04/05 02:38 AM
Ouch, that is an expensive fix.
Re: Transmission problem #581120 04/04/05 07:19 AM
Jake97T Offline
Sounds like the tranny shop bent you over, i wonder how much of that was all necessary...
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6283 MB (Peak: 0.7343 MB) Data Comp: Off Server Time: 2026-06-20 18:55:24 UTC
