Stock Rear height #581165 03/16/05 10:33 PM
The_Rusty_Gear Offline OP
Recently installed new "no-name" springs and my shocks look like they are almost fully extended. I'm thinking these springs have more than the stock arch. Is there a standard height measurement for springs? drum to fender? perch to shackle? ground to fender (tire dependant)?
1988 4Runner, V6 Auto, Mostly Stock
32 x 9.5 Swampers
Re: Stock Rear height [Re: The_Rusty_Gear] #581166 03/17/05 12:02 AM
G
Greg_Canada Offline
Measure from the upper lip of the rim to the fender. (state which size rim alos, 15", 16'?)
89 4Runner
Re: Stock Rear height [Re: Greg_Canada] #581167 03/17/05 12:18 AM
Definately a 15" rim. Will post my height tonite. What measurement should I be getting? (Should only be a 1/2" difference between 15 and 16" rims, right?)
32 x 9.5 Swampers
Re: Stock Rear height [Re: The_Rusty_Gear] #581168 03/17/05 12:34 AM
G
Greg_Canada Offline
It's up in the air, i rememeber a thread from about a year ago talking about it.
Mine measures 13.5" front, 12" back, and my springs are sagging.
I'd say around 13-14" is stock.
89 4Runner
Re: Stock Rear height [Re: Greg_Canada] #581169 03/17/05 01:14 AM
TAucoin Offline
Mine was about 14 rim to fender before cranked t-bars and body lift.
Re: Stock Rear height [Re: TAucoin] #581170 03/18/05 04:27 PM
Well, I measured and I was at 13.5" - Right about where I should be. Still looks strange that my shocks seem to be almost fully extended . . . . . (I even have shocks supposedly 1-2" longer than stock too!)
32 x 9.5 Swampers
Re: Stock Rear height [Re: The_Rusty_Gear] #581171 03/18/05 05:04 PM
4Crawler Offline
Could be whatever chart the shock place used to look up the 1"-2" longer shock is incorrect. I long ago gave up on what the applications sheets say and just measure for myself and order by p/n:
http://www.4crawler.com/4x4/Rancho.shtml
For the rear, I found the Rancho 5144 was about the longest stock you could stuff into the stock mounts and still have full compression to the bumpstops.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6174 MB (Peak: 0.6912 MB) Data Comp: Off Server Time: 2026-06-21 00:11:50 UTC
