Can I use a Holley carb on my 2.6? #581344 03/17/05 05:14 AM
Racer4 Offline OP
Hey, if I build an aluminum adapter plate, why can't I use a really small Holley carb on my 2.6 motor?
They came with accelerator pumps, and electric chokes.
So, why not a little 300 CFM two barrel unit?
Just asking. <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 Montero with Gen 3 alloys, 31 inch Toyo's, A/T, Dual Bouncy Seats, Midland CB radio, Rebuilding 2.6L . See the details http://www.cardomain.com/memberpage/710921
Re: Can I use a Holley carb on my 2.6? [Re: Racer4] #581345 03/17/05 05:25 AM
Someone has one here. I can't remember who or what details. I think he made an adapter that then mounted to a Weber plate.
Re: Can I use a Holley carb on my 2.6? [Re: Racer4] #581346 03/17/05 05:28 AM
FrankR Offline
If you want one, let me know - I have a Holley 82020 350 CFM marine (ideal for off-road) 2bbl (integral bowl) 2300 flange with electric choke - NIB just waiting for some lucky guy. <img src="/forums/images/graemlins/wink.gif" alt="" />
Frank
Re: Can I use a Holley carb on my 2.6? [Re: FrankR] #581347 03/17/05 05:33 AM
Racer4 Offline OP
Frank: I'm no Holley expert, but is your's different than this one I found? And how would I know which one would be better? Thanks for any info. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Part # 0-80320-1
Model # 2300
2-Barrel
300 CFM
Marine 302 CID - 5.0 Liter V-8
Electric choke
30cc accelerator pump
Single fuel inlet
5" airhorn
Adjustable Need and Seat
Power Valve Blowout Protection
Re: Can I use a Holley carb on my 2.6? [Re: Racer4] #581348 03/17/05 06:05 AM
FrankR Offline
Some differences:
1) 350 CFM
2) integral bowl (top gasket) - that one has a side mount bowl (think leaks)
3) cast aluminum color
4) dual fuel inlets (Y)
5) see-through fuel level sight plug
Other than that, they're probably pretty much the same. I think this one has a 6.5 power valve in it, but not certain. I don't think the montero pic site is working yet, but if you want I can email a pic to you.
Frank
Re: Can I use a Holley carb on my 2.6? [Re: FrankR] #581349 03/17/05 03:46 PM
Racer4 Offline OP
That would be great Frank. I'll PM you my E-mail addy. And one more question.
In the stock carb, is the electric choke controlled by the computer? Or is it just a signal that is either on or off? If just on/off then any electric choke carb will work. Correct?
Thanks, <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Can I use a Holley carb on my 2.6? [Re: Racer4] #581350 03/17/05 04:28 PM
FrankR Offline
The choke is actuated by a 12v lead taken off the ignition switch - 12v heats the coil which moves the choke valve - about the simplest choke arrangement you can have.
I don't know about OE electric carbs/ECU, but all Holley electric choke models I've seen are ignition switched on/off.
Frank
Re: Can I use a Holley carb on my 2.6? [Re: FrankR] #581351 03/17/05 04:41 PM
RockU Offline
I'll take one! My email is [email]jondanderson2002@yahoo.com....[/email] <img src="/forums/images/graemlins/patriot.gif" alt="" />
RockU - Federal Way, WA - 1989 Montero, New-2.6L, New-5spd, New Clutch, header, 10x15 wheels, 32x11.5x15 Mud Claw (Cardovan), 4" lift, Superwinch Hubs, Front LSD, Synch 38/38 Weber Carb, K&N filter, (Let's hit the trail!) Home Email: jondanderson2002@yahoo.com
Re: Can I use a Holley carb on my 2.6? [Re: Racer4] #581352 03/17/05 05:15 PM
grass13 Offline
mabey ive just gotten bias in my old age... my wife says im a cranky crusty dirty old man <img src="/forums/images/graemlins/ignore.gif" alt="" />. but ive never had good luck with holleys. in personal experiance, when theyre working right... they work great. but when they start to have problems, fixing them was a nightmare. fyi, avoid anything carter. edelbrock build a dam good carb, and if you go that route, AVOID THE STREET PRO... you wont be able to climb jack or articulate worth a crap. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Can I use a Holley carb on my 2.6? [Re: Racer4] #581353 03/17/05 08:21 PM
DMYERSCHATTTN Offline
I can still get my old Redline riser plate for the Weber 350 cfm carb, if anyone knows if that will work... I think it was a 2540, but not sure...
90 MONTERO ... Beat, Banged, 4DR recovery and recon vehicle... just keeps going and going...
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6463 MB (Peak: 0.7669 MB) Data Comp: Off Server Time: 2026-06-07 07:04:44 UTC
