No brake fluid
#581575
03/18/05 12:11 AM
So, I was coming home from church last night and the darn thing didn't want to shift. I figured the clutch had finally gone out, but then I looked in the master cylinder and noticed that there was no brake fluid. The clutch doesn't seem to be slipping at all (yay). This thing has almost 190K on it and still has the original clutch.
How should I proceed?
'95 Sportage 4x4 5speed SOHC bone stock, 200,000 miles and counting. The KIA isn't as powerful as the dually, but it sure is easier to park.
Re: No brake fluid
[Re: hayhauler]
#581576
03/18/05 12:28 AM
Kia Moderator Emeritus
Find the leak...fast! And don't drive it until you do.
The brake system and the clutch hydraulics share the same brake fluid. The first place to look for a leak is the clutch slave cylinder. It's located on the bellhousing on the passenger side.
If no leak there go over the brake lines from front to back. It's leaking somewhere.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
Re: No brake fluid
[Re: Axe Man]
#581577
03/18/05 02:28 PM
I also had some break fluid sipping down fro the ABS switch located next to the break fluid resevoir. I did not notice until I looked under the system. I just disconected the swith and the truck still stops fine and does not leak anymore.
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5931 MB (Peak: 0.6462 MB) Data Comp: Off Server Time: 2026-06-07 09:46:05 UTCValid HTML 5 and Valid CSS
