Ignition Problem?
#52399
05/17/03 08:31 PM
I was on the way to work yesterday and my '84 4Runner quit. It had been running fine... I put it on the trailer and brought it home. There is no spark. The cap and rotor are 2 months old and look great. There is 12+ volts at the coil when key is on. I did the "coil test" in the chiltons/haynes manuals and it did not look like there was any resistance across the coil. (they specify 0.4 to 0.5 ohms) So I bought a new coil. Still no spark. Parts store guy says igniter and pick-up coil are $300 each.
What should I check next?
Jason
1984 4Runner - V6 rear axle (locked by Lincoln), header, plenty of body cancer! Waiting for install: x-over steering, dual 'cases, twin-stick, 3" body & drivetrain lift, rear springs up front Still need: rear springs, 35" MT's, bumpers/sliders 2001 F350 - 7.3 110k miles on WVO conversion now!
Re: Ignition Problem?
#52400
05/17/03 11:58 PM
J Roll Me Over
Check another parts store! $300.00 for a "pickup???" <img border="0" title="" alt="[Eek!]" src="images/icons/shocked.gif" /> They are out of their mind. I am more than willing to bet the "pickup" went south, and you can "pickup" one for next to nothing from a boneyard. Heck, you can "pickup" an entire distributor with "pickup" in it for less than $50.
#52401
05/18/03 02:18 AM
yes, I wondered how much an aftermarket dist. was... is the pickup a common demon? is there a way to test it or the igniter?
Jason
#52402
05/18/03 11:26 AM
Jason, You could have possable broke the timing chain. Take off the dist cap and have a buddy turn the igniton key and crank her over a few times while you watch the rotor. I think it sould be turning cw when looking at if from the driver fender.. If the roter is not turning your timing chain has failed <img border="0" title="" alt="[Frown]" src="images/icons/frown.gif" />
HTH, RAZZ
87 4Runner 22R-TE 4 Pro Comp IFS 63 Chevy springs 5.71 gears Detroit in rear, Lockright in front 35 MT/R Rancho 9000 Jacobs ProStreet ign module and Ultra coil 1992 3VZ-E swapped in
#52403
05/18/03 04:32 PM
Razz, Rotor still turns... timing set only has about 15k miles. Anybody know how to test the pickup or igniter? thanks y'all
Jason
#52404
05/18/03 08:25 PM
Test the pickup by sticking the probes of an ohm meter into the slots, you should get a reading of like 140-180 ohms. Thats the range specified for my 88' anyways...yup just checkd the book, 82-84 and 88 140-180 ohms. air gap should be set to between .008 and .016 for all models through 88'. Most parts places around here tell me the pickup is non replaceable and an integrated part of the distributor...let alone "no longer available". I laughed at the Schucks counter man and went home where I propmptly ordered one from RockAuto on the east coast. Problem solved. There really isnt anyway to test the igniter that I am aware of. Generally they work one minute and are gone the next with no in-between. Find somebody with a similar ignition as yours and buy them a beer for letting you try their igniter on your system. If it works then buy one. If it dont then you just saved yourself some serious $$$. I hate people that throw parts at a problem...if they are so willing to throw their hardearned away...I'll give them my address. Did you bother checking all your fuses? Incab and engine compartment? ~Darin <img border="0" alt="[Baby]" title="" src="graemlins/baby.gif" />
88' 4x4 *22R-EB Gen II* 87' $Runner *22R-EB Gen I* 85' Sillyca 22R-Esq  "I LIVE IN MY OWN WORLD...THEY KNOW ME WELL THERE"
