89 and 90 Gas Tanks #582606 03/20/05 04:11 AM
barak Offline OP
Well , I finally got around totaking out the 2 gas tanks , and I found a couple of differences I am hoping somoen can help me clarify.One difference I think I can figure out myself , just a matter of running the hose a little different.The other part I think has to do with pumps built into the tanks.I have 8 pics here to try and point out the differences.I'll start with the tank from the 89 which is the good tank , the 90 tank leaks about half way up it.
Now , if you look at those pics , all 3 tubes ran the same path , one I think is a breather tube that goes off the little vent type thing on the end there.The other 2 tubes are on the same spot where that plug is with 2 wires , then on the side , which I didn't take a pic of for this one , there is another plug , and both plugs were plugged into each other.Now we go to the 90 tank.
This is a pic of the other plug that I didn't take a picture of off the 89 tank , but its an identical plug.
This one is showing the different style plug , and where the other hose went off and down the opposite side of the truck on that breather style tube in the middle.
This one shows the 2 plugs off the 90 truck , one of each plug on the tank , not like the 89 tank that just plugged into eachother.The next pic shows the extra plug end off of the tank.
I am assuming I just take the part off with the wire and the 2 hoses , and swap those parts , and that these are the fuel pumps?Correct me if I am wrong.And once I do that , I will have a good tank with no leaks , and the proper pump in the tank to plug into the wires on the 90 truck.Once this is done , its a matter of finishing up the rear end swap , only the leafs holding the rear on of the 89 , the 90 is all ready to pull.
Re: 89 and 90 Gas Tanks**UPDATE** [Re: barak] #582607 03/21/05 12:06 AM
barak Offline OP
I just finished painting the tank and the skid plate.Regarding that extra wire , I just cut it off the tank that leaks(I'll fix that one later) and used some butt connectors and put it onto the other tank.Now I just need a longer piece of hose to get that other hose to reach due to the different set up between the 2 tanks , and it should be good to go.Thats all I got done today though , painting the tank and skid plate.Oh well , maybe tomorow I can get those last leafs off and pull both rear ends , they will go together a lot easier than taking them apart <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 89 and 90 Gas Tanks**UPDATE** [Re: barak] #582608 03/21/05 11:58 AM
ravencr Offline
I can't fully tell from your pics, but is your tank the same as a 1994 Rodeo tank?
Chris
Re: 89 and 90 Gas Tanks**UPDATE** [Re: ravencr] #582609 03/21/05 05:42 PM
barak Offline OP
Not sure if the tank would be the same or not.These are off a 89 trooper 2.6 and a 90 trooper 2.8.It is possible the tanks are the same for isuzu , but you never know.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6047 MB (Peak: 0.6791 MB) Data Comp: Off Server Time: 2026-06-21 11:14:55 UTC
