Supercharger Questions #584169 03/23/05 07:31 PM
Jake97T Offline OP
Im considering buying a TRD supercharger, but concerned about reduced fuel efficiency, lean out, and pinging. Is it necessary to upgrade the fuel system with a URD kit, will i get worse gas mileage, etc. how much will this cost???
Re: Supercharger Questions [Re: Jake97T] #584170 03/23/05 07:53 PM
H2O_MAN Offline
Your '97 should not have any issues that require the URD items.
If you can control your right foot your MPG shoul get better by 1 or 2 mpg.
Re: Supercharger Questions [Re: H2O_MAN] #584171 03/23/05 10:06 PM
Jake97T Offline OP
So is the pinging really suttle with the S/C or is it pretty bad? Does anybody know what RPM range the lean out becomes a problem or is it just at WOT?
I figure the first tank of gas with a supercharger will go pretty fast and then ill have to settle down...
Re: Supercharger Questions [Re: Jake97T] #584172 03/26/05 03:33 AM
W
Will_I_Am Offline
If you use anything but premium fuel it will ping at high RPM, you must use super, i have not found any bad issues other than the fact that you cannot keep your foot out of the tank thus you burn a little more gas but once you get over the "newness" of the s/c you will see your gas mileage change by 1 mpg that is what i saw...
William
William Gabay
Re: Supercharger Questions [Re: Will_I_Am] #584173 03/30/05 07:02 AM
4
4xGeek Offline
Jake~
Something else that may be a little problematic is your chip (ECU)... From what I understand, they don't work well with the s/c. <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Supercharger Questions [Re: 4xGeek] #584174 03/30/05 03:23 PM
Jake97T Offline OP
ive heard that as well, ive decided not to get a supercharger. I just put 35's on yesterday, kind of makes me wonder where else i can search for power...any ideas
Re: Supercharger Questions [Re: 4xGeek] #584175 03/30/05 04:28 PM
H2O_MAN Offline
Jake~
The ECU's in '97 and '98 T100's will work just fine with the S/C.
Also, the TRD headers do add some power and driveability.
Re: Supercharger Questions [Re: H2O_MAN] #584176 03/30/05 05:15 PM
Jake97T Offline OP
I think 4xGeek is referring to an added pinging and lean out problem that could be associated with the combo of a S/C and a Jet Chip,
I talked to URD about it a little, all they suggested i do was order their 00001 kit which is close to a grand, too much spending for me.
Re: Supercharger Questions [Re: Jake97T] #584177 03/30/05 09:16 PM
BIG-T Offline
Gear it down to 4.88's and you'll be fine. Get the SC and you'll be ok too just make sure to run the highest octane that you can. The point where you get the most ping is under 3k rpm and under load. You get used to it after a while and you just remember to downshift before you mash the gas pedal. I have had mine for about 2 years with no problems at all and I put it on a motor that had 214k and it now has 280K with no problems and a stock exhaust. I just took it down to Phoenix this past weekend to pick up an 800lb motorcycle and other then resetting the ECU when I was there it drove just as good as up here in Colorado but with a bit more power. It also did 90 mph going up all the mountains in Arizona. <img src="/forums/images/graemlins/smile.gif" alt="" />
BTW I get 16-18mpg with current setup
Hey Jake can you post a pic of your truck with the fiberglass fenders
Thnx
97 T100, supercharged, 5spd,and 256k miles.......SAS Dana 44, 4:88 gears, locker, 37" MTR's............ <img src="/forums/images/graemlins/smile.gif" alt="" />
http://www.cardomain.com/memberpage/596514
Re: Supercharger Questions [Re: BIG-T] #584178 03/30/05 10:44 PM
Jake97T Offline OP
Ive got 4.88s in my truck right now, they're great,
Going to need a tutorial on how to post a picture of my truck...PM me anybody, i dont have a website or anything so is it possible???
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6379 MB (Peak: 0.7625 MB) Data Comp: Off Server Time: 2026-06-22 01:13:19 UTC
