Overload Leaf crooked #584841 03/24/05 10:29 PM
Jake97T Offline OP
Ive got 2" AAL and 2" blocks (superlift) on my leaf springs, my overload leaf is crooked. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Overload Leaf crooked [Re: Jake97T] #584842 03/25/05 03:35 AM
H2O_MAN Offline
I started having that problem soon after installing AAL's then came the spring perch axle cracks.
I had the axle cracks welded and installed a custom set of Alcans - no more problems
Re: Overload Leaf crooked [Re: H2O_MAN] #584843 03/25/05 05:13 AM
Jake97T Offline OP
My guess is they have been like that for years before i bought the truck, they have been crooked for the 2 years ive owned it now. No cracks on my spring purches, crossing my fingers,
How much for the Alcans H2OMan???
Re: Overload Leaf crooked [Re: Jake97T] #584844 03/25/05 05:54 AM
H2O man - My T100 has been stock until now and I have perch cracks at my axle tube. How did you go about welding? Did you take apart the whole rear end? Probably stupid question, but what are Alcans?
Re: Overload Leaf crooked #584845 03/25/05 12:57 PM
H2O_MAN Offline
Alcan's -- http://www.alcanspring.com/
As for the cracks, I took it to a local shop and had them weld it. Do a search for the details - many T100's have had this little problem.
Re: Overload Leaf crooked #584846 03/25/05 03:42 PM
surlynkid Offline
undo ubolts, and remove shocks and lower shock mount. clean up area really well. move brake line out of the way if you need to and then weld it up.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Overload Leaf crooked [Re: surlynkid] #584847 03/25/05 07:09 PM
Chemical442 Offline
I welded mine last month. If you gingerly bend the brake line hanger up, you don't have to worry about removing any brake lines. A Dremel and some brake cleaner and an air gun will get it cleaned just fine. No need for major disassembly. LOL
I just bent my brake hanger up about an inch and a half, cleaned the small area I needed to weld, and started welding. It shouldn't be made any harder than that.
=Brian=
96 T-100 4X4 XCab 5-Speed
46 Willy's CJ-2A
Re: Overload Leaf crooked [Re: Chemical442] #584848 03/26/05 01:54 AM
surlynkid Offline
heaven forbid we weld without a beer close by. i welded jroc's up a year ago. it is holding fine.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: Welding [Re: surlynkid] #584849 03/26/05 02:30 AM
Thanks dudes... what kind of welders did you guys use? Mig with the gas tank? I actually ran into an old friend who works at a welding shop, so I'll take it to him most likely, but I was just curious what tools y'all are using. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Welding #584850 03/26/05 03:57 AM
Jake97T Offline OP
Hey what about me and my needs??? LOL
Still got a crooked overload leaf, anybody got u-bolt flip kit on theirs??? Ideas of new springs?
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6369 MB (Peak: 0.7610 MB) Data Comp: Off Server Time: 2026-05-30 01:15:49 UTC
