Dana 35 confused numbers.... #584894 03/24/05 11:54 PM
NCBBA2358 Offline OP
Okay, I don't spend a lot of time looking for things to read on my Jeep, just books and quick once-over inspections of things. I was a little bored this afternoon, chatted all the way to Washington state on the CB, sharpened the chains for my chain saw and then wondered what was actually printed on the rear axle for IDs. I know what the top two are, but the others are a little confusing....
TOP RIGHT: 35C (with a strange symbol under it, perhaps a design from the mold....)
TOP LEFT: 35C
LOWER LEFT: 347
LOWER RIGHT: 5
Then on a tag that is attached by a cover bolt at about the 4:00 position... "11480"
What does the 347, 5, 11480 numbers stand for and mean?
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
Re: Dana 35 confused numbers.... [Re: NCBBA2358] #584895 03/25/05 01:01 AM
3.47 is the gear ratio
Re: Dana 35 confused numbers.... #584896 03/25/05 05:10 AM
TX4wl Offline
3.55 would be the correct they only came 3.07,3.55,3.77,4.10 IFCC... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Dana 35 confused numbers.... [Re: TX4wl] #584897 03/25/05 05:11 AM
TX4wl Offline
mine came out as a 3.44, but it was a 3.55 << hope that makes sence
Re: Dana 35 confused numbers.... [Re: TX4wl] #584898 03/25/05 05:38 AM
Okay, a couple back steps....
This is a replaced axle. It came from Jasper in Atlanta in 1998 and was put together and installed in Newark, NJ (Scary place for a southern white dude to break down....) I'm pretty sure that they used the origional gear ratio as they didn't touch the front and they are a paired set of gears....
So, it would have 3.47:1 gears (theoretically) and are most likely 3.55:1?
Question still remains regarding the 11480 and the 5.....
Re: Dana 35 confused numbers.... [Re: NCBBA2358] #584899 03/25/05 05:43 AM
Exar Offline
Lucky you I have 3.07 gears that sucks
90 YJ
Rubicon Express Extreme Duty 4.5? lift
Ford 8.8
4.11's
33" Super Swampers
Newly added 2000 WJ
Re: Dana 35 confused numbers.... [Re: NCBBA2358] #584900 03/25/05 06:46 PM
Unless you had the jeep re-geared, the stock ratio for a 91 yj with a 5 speed is 3.07. They never made a 3.47, they are either 3.55's or 3.07's.
Re: Dana 35 confused numbers.... #584901 03/25/05 07:52 PM
I'd look at the tag on the front axle to determine the gears. If it hasn't been replaced, the tag on it should be the factory tag and it will give both the ratio and the gear tooth numbers for the ring and the pinion.
Re: Dana 35 confused numbers.... #584902 03/25/05 11:09 PM
Front axle isn't much help. See below for legend for these line by lines.... All of these except for D are stamped or cast into the steel. Two lines of D are on a tag stamped with the information provided.... Line D2 could indicate that there are 3.07:1 gears, so, is the rear just a heavier case with the same gear set? Never had any problem with the front and rear competing with eachother. The tag on the rear axle, with the "11480" is from the origional rear axle, but doesn't give any help....
A û 42283 28 D1 J
B û 610362 2RC 6-16-91 8A
C û some ôtriangleö looking symbol
D û 2 lines:
D1 û 53009327
D2 û 3 07 610362-2
E û 5 lines:
E1 û DANA
E2 û 40869
E3 û 117 1
E4 û REV-E
E5 û 11-22-88
F û 288
G û 2
Re: Dana 35 confused numbers.... [Re: NCBBA2358] #584903 03/25/05 11:22 PM
BigJim Offline
A û 42283 28 D1 J
D û 2 lines:
D1 û 53009327
D2 û 3 07 610362-2
E û 5 lines:
E1 û DANA
E2 û 40869
E3 û 117 1
E4 û REV-E
E5 û 11-22-88
F û 288
G û 2
There ya go! 3:07 it is then! And whoever made the rear absolutely has the same 3:07 in it too. Now you have good proof of how high that ratio really is.
Big Jim
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6278 MB (Peak: 0.7491 MB) Data Comp: Off Server Time: 2026-11-02 14:20:00 UTC
