tach opinions #584907 03/25/05 12:05 AM
willzrunna96 Offline OP
what kind of tachs do you guys run and where did you install them. im looking for somethine to fit in a pod or something that looks stock. i dont feel like looking for a bling bling tach. could i swap in a sr5 gauge cluster?
Re: tach opinions [Re: willzrunna96] #584908 03/25/05 01:50 AM
87Toy4x4 Offline
the sr5 cluster would be the way to go. thats what i did. very simple to install.
Re: tach opinions [Re: willzrunna96] #584909 03/25/05 02:36 AM
stock87 Offline
Easy swap, see my sig for a writeup for 2nd gens. For your truck, you'll want to get a pre-93 cluster unless you want to switch to an electric speedo. http://www.installdr.com/ has good instructions for taking apart your dash. Other than that, pretty much plug and play. Just watch out for the oil pressure sender caveat.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: tach opinions [Re: willzrunna96] #584910 03/25/05 03:57 AM
Kaptain Offline
..If you didn't want to swap in a new cluster you can easily wire in a 2 1/2 in sunpro tach.. ( Quite a few of us are running them). Easily mountable to the plastic steering column.. Not the best pic, but it gives you an idea. [Linked Image]
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: tach opinions [Re: Kaptain] #584911 03/28/05 10:06 PM
DRM Offline
I went with the Sunpro Mini tach in my 90 model truck. Took the bracket, twisted it a half turn, and mounted it to the base of the A pillar. it fit snugly there just above the dash, was out of the way, and did not block driving vision or any other gauges.
I may have a pic burried on my website somewhere, I will see if I can find one.
Re: tach opinions [Re: DRM] #584912 03/29/05 06:19 AM
87Toy4x4 Offline
i had the sunpro mini tach and i hated it it looks cheap and makes you look like ricer. but if your into that kind of thing thats cool, haha. it did a good job though but was a little too small.
Re: tach opinions [Re: 87Toy4x4] #584913 03/29/05 03:28 PM
grandeyota Offline
I took a sunpro mini tach and a self tapping screw and put it on the plastic thing on the steering column. After about 6 years it's gotten pretty sun faded.
Fur clog in the sausage grinder
Re: tach opinions [Re: grandeyota] #584914 03/29/05 04:02 PM
John Smith Offline
Yet another happy Sunpro minitach user. Been running one on the column for seven years or so. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
John Smith 79 FJ40
87 StdCab w/22R TLCA# 9074
Re: tach opinions [Re: willzrunna96] #584915 03/29/05 04:44 PM
TheBandit Offline
I have used both Sunpro and Autometer in my hotrod and Toyota. The Sunpro works just fine. The reason I went Autometer was for a shiftlight, which for the hotrod is a must have. In the Toyota it would be cool to have too, but I think the good old lightless tach is fine. I do, however, prefer a larger face. My Toyota has a 2 5/8s right now, which is barely big enough I think. I have a 5" monster mounted to the pillar of my Nova - very visible!
The Toyota's is mounted to the dash. Yes I drilled holes in a perfectly good dash - and I'll never look back; it's the best damn place for a tach and if I didn't care so much about the original dash in my Nova, I would have put it there on it too. Here are some pics:
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: tach opinions [Re: TheBandit] #584916 03/29/05 07:59 PM
Another vote for Autometer. I've got the same 2 5/8" all black tach and love it. I had mine mounted on the A pillar, but I just install three new Autometer gauges in a pod on the pillar and moved the tach to the steering column. It blocks the gas gauge a little but all you gotta do is move a little to see it. Sunpro just looks cheap, and ya get what ya pay for.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6296 MB (Peak: 0.7378 MB) Data Comp: Off Server Time: 2026-11-01 15:12:19 UTC
