head bolt torque #584917 03/25/05 12:36 AM
swamprocket Offline OP
I know the proper torque on 22r head bolts is 58 ftlbs, but I have also seen publications that say 62. Would that be a bad idea to torque them a little more? I mean I can't even count the number of 22r's I've seen with blown headgaskets lately. I realize they are not that hard to work on, but a blown headgasket in the middle of a snowstorm when you are trying to go duck hunting sucks!
94 mini pickup
01 runner
Re: head bolt torque [Re: swamprocket] #584918 03/25/05 01:12 AM
BennyBoy Offline
If your insalling a head, Its a good idea to use ARP head studs. With the ARP's I used on my 22r, I went to 92ft-lb. With stock head bolts I run them to 60ft-lb. with a nice coating of Never-Sez.
Always seems to work out well.
Re: head bolt torque [Re: BennyBoy] #584919 03/25/05 04:20 AM
kyle-22r Offline
where'd you get the 92lb number? my studs said that with their moly lube, torque them to 80lbs, and with 30wt oil, torque them to something like 120?
'91 4x4 shortbed
22R-E, W56, the dd!
Re: head bolt torque [Re: swamprocket] #584920 03/25/05 04:51 AM
engnbldr Offline
[quote]I know the proper torque on 22r head bolts is 58 ftlbs, but I have also seen publications that say 62.
____________________________________________________________
>>>*The spec is 58 lbs ft, we always torque them to 58 initially, then at retorque after warmup/breakin we will use the 60# to 62# figure....*EB
*Beats the he** outa me!....*LOL**...
Re: head bolt torque [Re: engnbldr] #584921 03/25/05 06:23 AM
Toy Story Offline
Ditto. You gonna argue with him? <img src="/forums/images/graemlins/wink.gif" alt="" />
85 Toyota SR5 Xtra Cab P/U
Re: head bolt torque [Re: kyle-22r] #584922 03/25/05 10:45 AM
BennyBoy Offline
The tech at ARP thru that spec at me(because I used Never-Sez).
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6102 MB (Peak: 0.6801 MB) Data Comp: Off Server Time: 2026-06-15 10:34:40 UTC
