Boot Rot on Carb? #585243 03/25/05 09:04 PM
javven Offline OP
OK, on the driver's side, towards the rear of the carb there's a pushrod that runs vertically. It goes into some kind of assembly that has a boot sealing the pushrod. It's about... 1/8th inch diameter rod? The boot on this is dry rotted.
Problem? How should I address this?
Change your oil hot and often.
07 Taco V6 4WD 5-Auto
Re: Boot Rot on Carb? [Re: javven] #585244 03/25/05 09:12 PM
LRJ4x4 Offline
Thats the Dashpot throttle opener. You could try getting a carb kit and see if it's in there. I doubt it.
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Boot Rot on Carb? [Re: LRJ4x4] #585245 03/25/05 10:00 PM
javven Offline OP
Dashpot. What does the #@$ on my dash have to do with it? <img src="/forums/images/graemlins/evil.gif" alt="" />
Seriously, what's that?
Re: Boot Rot on Carb? [Re: javven] #585246 03/25/05 10:28 PM
LRJ4x4 Offline
When you turn the AC on it open's the throttle to raise the RPM's . I think it also slows the throttle from closing to fast which would cause a jerking motion.
That boot is nothing more than a dust cover. I wouldnt worry about it to much. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Boot Rot on Carb? [Re: LRJ4x4] #585247 03/25/05 10:33 PM
javven Offline OP
Sweet. You're the man. I was just hunting down vac leaks. carbnchoke didn't cause a surge so i was pretty sure...
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6073 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-11-15 15:58:11 UTC
