LSPV Rod #586171 03/28/05 08:24 PM
Smoke Offline OP
Is the LSPV spring rod suppose to be straight or does it have a large bow in it? I recently had a limb hang up between the spare tire and rear differential, after my brakes started acting funny, I noticed the the LSPV rod was bent in a bow as if it was clearing the spare tire. It will clear the tire even if straight but have never paid alot of attention to it till I started having the funny feeling braking problem and remembered the limb being hung under there. The FSM shows it as being straight but can't really say!!
94 P/U Ex-Cab 3.0 Automatic 4X4
Re: LSPV Rod [Re: Smoke] #586172 03/28/05 08:58 PM
4Crawler Offline
Mine *was* nearly straight as I recall:
One way to check is to see where the sensing arm is relative to the LSPV. If it it pushed clear to the top of travel due to the bend, then that is too heavy on the rear brakes and they will lock up first. Try bending it straighter to set the sensing rod a little below the full up position.
I got rid of mine many years ago:
http://www.4crawler.com/4x4/4R_suspension.shtml#ProportioningValve
Re: LSPV Rod [Re: 4Crawler] #586173 03/28/05 11:15 PM
anthony1 Offline
I did something similar to Roger's mod. Man, what a difference.
My stoping distance increased after SAS. I'd adjust the lever but it's still not to my satisfactory. I found that my truck lean forward too much so the rear wasn't getting enough brake presure. Since I did the mod, it's much better.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: LSPV Rod [Re: anthony1] #586174 03/29/05 02:31 AM
Smoke Offline OP
I adjusted on the rod some and it improved but what are you refering to about Roger's Mod?? Thanks everybody that's replied!! <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: LSPV Rod [Re: Smoke] #586175 03/29/05 03:30 AM
4Crawler Offline
You can click on the link I put in my earlier reply to see one option for the LSPV sensing arm.
Re: LSPV Rod [Re: 4Crawler] #586176 03/29/05 04:23 PM
Smoke Offline OP
Thanks 4crawler, I must have overlooked that the first time around. By the way I have enjoyed and used alot of your write ups and website, I'm sure that they have helped alot of us out!! Thanks for them!!
Re: LSPV Rod [Re: Smoke] #586177 03/29/05 06:09 PM
anthony1 Offline
There you go.
<img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6206 MB (Peak: 0.7119 MB) Data Comp: Off Server Time: 2026-06-07 03:20:19 UTC
