Simple horn question #586537 03/29/05 08:04 PM
4X4_Canuck Offline OP
Hey all,
Havent got much accomplished this winter..too cold <img src="/forums/images/graemlins/baby.gif" alt="" />
But, I am currently installing the Hella triple air horns <img src="/forums/images/graemlins/mrt.gif" alt="" />
Does anyone know which way Mitsu wires the old horns:
a) Power to + when needed, always grounded.
or
b) + is always hot, beeping caused by grounding connection.
Thanks !
91 SWB V6 Raider. (Japan)
R/H Drive. Rear Lock.
32x11.5 BFG A/Ts w/ 15x8 rims
1000 watt Kenwood amp w/ 2 10"JBLs
Re: Simple horn question [Re: 4X4_Canuck] #586538 03/29/05 08:37 PM
DMYERSCHATTTN Offline
I'm not certain, but I believe it beeps when grounded, because I had to disconnect mine when it wouldn't shut up. <img src="/forums/images/graemlins/ignore.gif" alt="" />
90 MONTERO ... Beat, Banged, 4DR recovery and recon vehicle... just keeps going and going...
Re: Simple horn question [Re: 4X4_Canuck] #586539 03/29/05 08:39 PM
conner Offline
Horns are supplied power by the ignition switch and grounded by the column switch.
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: Simple horn question [Re: DMYERSCHATTTN] #586540 03/29/05 08:39 PM
DougH Offline
Mitsubishi Forum Moderator
Allways hot... beeps when grounded. It is grounded through the horn button. There is a spring loaded contact in the steering column the makes the connection from the horn button to the chasis. Any horn that is grounded through the case is going to give you a big head ache lol.
DougH
1995 SR - RIP
1993 RS - RIP
Re: Simple horn question [Re: 4X4_Canuck] #586541 03/29/05 08:39 PM
FrankR Offline
b)
Frank
Re: Simple horn question [Re: FrankR] #586542 03/30/05 03:08 PM
Thanks a lot guys !!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6068 MB (Peak: 0.6762 MB) Data Comp: Off Server Time: 2026-06-17 16:42:47 UTC
