cleaning the intake manifold #586635 03/30/05 12:41 AM
ok guys, while i have the head and everything off to fix the head gasket, i got a bit of time before it comes in, so whats the best way to clean up the intake manifold
theres alot of carbon and stuff built up in there, its really hard to get out with a toothbrush and throttle body cleaner like i have been doing
thanks
Re: cleaning the intake manifold #586636 03/30/05 12:54 AM
Esquire812 Offline
OVER CLEANER!
While the label will state that it is not intended for use on aluminum...I havent had any ill effects from using it myself. Liquid Dishwasher soap is pretty acidic as well...does amazing things to old ugly metal.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: cleaning the intake manifold [Re: Esquire812] #586637 03/30/05 12:57 AM
OOP'S Offline
The two things Darin said or take it and have it hot tanked!!! <img src="/forums/images/graemlins/notooth.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: cleaning the intake manifold #586638 03/30/05 01:53 AM
bard Offline
Watch getting those cleaners on the outside unless you want it to look hazy.
Re: cleaning the intake manifold [Re: bard] #586639 03/30/05 02:38 AM
anthony1 Offline
Have you try drive way cleaner?...the bio degradable kind.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: cleaning the intake manifold [Re: anthony1] #586640 03/30/05 05:44 AM
87Toy4x4 Offline
the oven cleaner just makes it have this white dust stuff on it that you have to wire brush off if you leave it on too long but it doesnt hurt anything. i used it on my timing chain cover and valve cover, worked good. simple green and purple power also work well. get a good set of brushs also. but i didnt have any carbon buildup on the inside of my intake manifold. i wonder why?
Re: cleaning the intake manifold #586641 03/30/05 06:42 PM
guill Offline
I've always use TB cleaner with good result.
Start your truck then shoot inside air intake (take off filter). The motor will likely die so you need to give some throttle. spray at least half can of cleaner.
Then stop engine and take off air intake pipe. Spray inside throttle + brush if needed + then try to start motor (may turn more then usualy).
I do mine each 6-8 months
Guill
88 4Runner 22RE 4x4
Montreal Canada
www.hexcostainless.com/images/fart.gif
Re: cleaning the intake manifold [Re: guill] #586642 03/30/05 10:40 PM
thanks guys
got it clean enough with tb cleaner, and a cloth attached to a flexable drillbit
and i picked up a HG today, so tomorrow it all goes back together hopefully
Toyota Headgaskets look far superior to the old one (felpro)
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6155 MB (Peak: 0.6973 MB) Data Comp: Off Server Time: 2026-06-09 10:00:57 UTC
