Smoking 3.0 #586856 03/30/05 04:25 PM
4WDJOE Offline OP
I got an '89 LWB 3.0 that smokes, but runs great. The valve seals are getting replaced, but if that doesn't cure the problem, is there something else I should be looking for? Thanks in advance. <img src="/forums/images/graemlins/cheers.gif" alt="" />
97 Rodeo
Re: Smoking 3.0 [Re: 4WDJOE] #586857 03/30/05 04:28 PM
FrankR Offline
Ring wear could also cause the smoke - but it's more likely the valve seals. A compression test will show ring wear.
Frank
Re: Smoking 3.0 [Re: FrankR] #586858 03/30/05 04:34 PM
4WDJOE Offline OP
Compression was only checked in 3 cyls, but they were fine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
97 Rodeo
Re: Smoking 3.0 [Re: 4WDJOE] #586859 03/30/05 04:35 PM
javven Offline
Lower end would usually be oil control rings. Upper end would be valve seals (it's upper end - on this motor? even if your lower end is also having some blow-by the top end needs attention I'm sure).
It's also possible you're blowing too much crank gas into the intake - that happens on my volvo from time to time. Can't remember is the 3.0 is prone to the same issue.
Change your oil hot and often.
07 Taco V6 4WD 5-Auto
Re: Smoking 3.0 [Re: 4WDJOE] #586860 03/30/05 04:37 PM
FrankR Offline
That's good, but unless you check every one, you can't be sure.
Frank
Re: Smoking 3.0 [Re: FrankR] #586861 03/30/05 04:38 PM
FrankR Offline
Also, if the PCV valve hasn't been replaced, try that.
Frank
Re: Smoking 3.0 [Re: 4WDJOE] #586862 03/30/05 05:36 PM
The valve seals should take care of your problem. Most of the 3.0 heads that I've rebuilt had bad seals.
Cal <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Smoking 3.0 #586863 03/30/05 05:59 PM
Mendel Offline
I replaced the valve seals on my 91 at 120,000 miles and it didn't fix the problem. Once I replaced the heads, the problem was solved. The seals were definitely bad but they weren't the only problem on my engine.
I'm not sure if there is a way to tell when the valve seals are enough or when the entire top end needs to be redone. Anybody have any ideas?
1991 Montero LS, fading red paint
Front and rear limited slip differentials
95 SR Rear Springs, torsion bar crank, 137,650 miles
33x12.5 ProComp Mud Terrains, Bushwacker Fender flares
3 litre V6 with new heads
Re: Smoking 3.0 [Re: Mendel] #586864 03/30/05 06:03 PM
javven Offline
Forgive my ignorance but where would the heads come into play if the VS were replaced?
Re: Smoking 3.0 [Re: FrankR] #586865 03/30/05 07:41 PM
4WDJOE Offline OP
Frank
I agree, it was the previous owner that checked and informed me, he's now doing the seals and then we'll see.
97 Rodeo
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6369 MB (Peak: 0.7428 MB) Data Comp: Off Server Time: 2026-06-06 23:18:51 UTC
