How to weld diffy spider gears #586976 03/30/05 07:35 PM
CraShYota Offline OP
where and how do i weld the spidergears to lock my differential. toyo 8"...
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: How to weld diffy spider gears [Re: CraShYota] #586977 03/30/05 07:48 PM
DRM Offline
Weld gears to gears and gears to carrier and anywhere else in there you can weld to something else.
here's one that I sold recently that held up just fine on and off road:
Re: How to weld diffy spider gears [Re: DRM] #586978 03/30/05 10:22 PM
G
Greg_Canada Offline
Ain't that a 4cyl diff? (DRM)?
I think that guys got a V6...
89 4Runner
Re: How to weld diffy spider gears [Re: Greg_Canada] #586979 03/30/05 11:03 PM
I've always wondered why there isn't a write up on welding your diff.
Re: How to weld diffy spider gears [Re: DRM] #586980 03/30/05 11:59 PM
TheBandit Offline
I feel there is a big misconception about welding as much as you possibly can. Welding is inadvertantly a heat treating process which can severely impact the strength of the components in the carrier. Welding here there and everywhere doesn't necessarily improve the strength of a welded diff.
I would say you should weld surgically, working slowly to allow heat disipation (weld, stop, weld, stop, etc). Do not quench the welds with water, as you can make them brittle. Allow them to air cool gradually.
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: How to weld diffy spider gears [Re: CraShYota] #586981 03/31/05 12:54 AM
4xJedi Offline
DRM is right, gears to gears then side gears to carrier. It's best to nickel weld and peen the weld to de-stress it as it cools. Let the weld cool as slowly as possible. Here's a bad pic of one I did. Also it's best to do this with the carrier out of the third. If you leave it in you'll play hell trying to get all the chipped slag out.
'86 4Runner 5" SAS
'97 4Runner
'05 Corolla
'00 F250 PowerStroke
Re: How to weld diffy spider gears [Re: 4xJedi] #586982 03/31/05 01:01 AM
Hey 4xjedi, that your diff? Move the lockright up front?
Are you still making the rag top brackets/bars? I might want one this summer. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: How to weld diffy spider gears #586983 03/31/05 02:28 AM
4xJedi Offline
No that's a 4.37 I did for practice before I weld yours <img src="/forums/images/graemlins/notooth.gif" alt="" />. Kits are still for sale.
'86 4Runner 5" SAS
'97 4Runner
'05 Corolla
Re: How to weld diffy spider gears [Re: Greg_Canada] #586984 04/06/05 02:37 PM
yeh 88toy has a 4cyl diff with a v6 engine...
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6232 MB (Peak: 0.7217 MB) Data Comp: Off Server Time: 2026-11-01 22:23:36 UTC
