Page 1 of 5 1 2 3 4 5
Ways to stop a running truck your locked out of. #587028 03/30/05 10:00 PM
LRJ4x4 Offline OP
No I'm not locked out, I have spare keys.
There was a recent post on the tech side about a guy who locked himself out of his truck while it was running. It sat for 4 hours at idle.
I was thinking of ways to stop it from running without having access to the cab or hood. Here are my idea's feel to shoot them down. <img src="/forums/images/graemlins/lol.gif" alt="" />. I'm looking for least amount of damage other than breaking and entering.
1. Stuff 4 pototes in tail pipe ( cause it to stall? )
2. Remove gas cap, cover with platic wrap and rubber band on outside ( fuel lock? )
3. slide under and pinch the fuel line with vise grips
4. Cover car with big platic tarp and sandbad or tape to ground ( make sure your on outside smile
5. add lots of water to fuel ( monty has drain right )
6. Zap it the high tech police car zappers ( saw on TV <img src="/forums/images/graemlins/smile.gif" alt="" /> )
Re: Ways to stop a running truck your locked out of. [Re: LRJ4x4] #587029 03/30/05 10:12 PM
FrankR Offline
Cut the wires to the fuel pump.
Remove the passenger side fender splash guard and stick a rag in the air intake.
Frank
Re: Ways to stop a running truck your locked out of. [Re: FrankR] #587030 03/30/05 10:30 PM
javven Offline
From behind the driver side front wheel, reaching diagonally up towards the top-front of the hood, if you had a bent bit of wire (thick, tough wire - tougher than a coat hanger) you might be able to yank the dizzy wire on a 4-banger. You would definately need a good light and some patience.
Change your oil hot and often.
07 Taco V6 4WD 5-Auto
Re: Ways to stop a running truck your locked out of. [Re: javven] #587031 03/30/05 10:34 PM
Or you could bend a peice of coathanger into a fish hook shape, fish down into the wonderfully uncomplex Gen 1 door, hook the rod the lock is on and pull up. It scares me how easy it is to get in our trucks.
Re: Ways to stop a running truck your locked out of. #587032 03/30/05 10:37 PM
javven Offline
I know about that but wasn't going to mention it.
Re: Ways to stop a running truck your locked out of. #587033 03/30/05 11:03 PM
87Montero Offline
Exactly how my montero was broken into... <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Ways to stop a running truck your locked out of. [Re: 87Montero] #587034 03/30/05 11:43 PM
LRJ4x4 Offline OP
All regular cars are easy to break into. Walk up with spring loaded punch and pop instant safety glass <img src="/forums/images/graemlins/lol.gif" alt="" />
Locks only keep the honest out. In LA if the pro's want your car they pull up in a box truck, two gallons of bleach and a hydralic winch inside. 30 seconds later your dragged into the back, lojack, car alarm and steering wheel club is of no use <img src="/forums/images/graemlins/angry.gif" alt="" />
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Ways to stop a running truck your locked out of. [Re: LRJ4x4] #587035 03/30/05 11:52 PM
javven Offline
Bleach?
Re: Ways to stop a running truck your locked out of. [Re: javven] #587036 03/31/05 12:07 AM
JunkIt Offline
I wish they would of Jimmied the lock on my door. Instead they broke the back drivers side window 3 times and broke both drivers side handles.
Back on topic : I would just remove my trusty coat hanger I have stashed on the frame rail and open the door.
Re: Ways to stop a running truck your locked out of. [Re: JunkIt] #587037 03/31/05 12:12 AM
i think the bleach is so when they are pulling the car, the bleech is laid down so they wont make noise and it will go easier. did i vision that right?
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6414 MB (Peak: 0.7639 MB) Data Comp: Off Server Time: 2026-06-20 17:54:12 UTC
