Page 2 of 3 1 2 3
Re: No Fire, ( all of a sudden???) [Re: conner] #587393 04/02/05 06:39 PM
By testing the transistor that way, does that mean the
transistor is good or just the coil? <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: No Fire, ( all of a sudden???) [Re: FrankR] #587394 04/02/05 07:02 PM
Well, I found one, transistor $30.00
Should be here Wednesday <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: No Fire, ( all of a sudden???) #587395 04/02/05 09:24 PM
FrankR Offline
Good - where'd you get a transistor only? New or used?
Frank
Re: No Fire, ( all of a sudden???) [Re: FrankR] #587396 04/02/05 09:35 PM
Spalding Auto in Spokane, WA (used)
1-800-366-2070 <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: No Fire, ( all of a sudden???) #587397 04/02/05 09:46 PM
FrankR Offline
I was hoping it was a place we could buy new spares - but as long as it works, no matter whether it's new or used to me - those things seem to work for either 10 seconds or 15 years. At that price it's good to have a spare - if for nothing else - troubleshooting.
If your truck is the same as mine, you still have an LC filter and a capacitor on the coil assembly (backside underneath. I suppose either one could cause a problem but I haven't dealt with either.
Frank
Re: No Fire, ( all of a sudden???) #587398 04/04/05 01:20 PM
conner Offline
Think about the tests that i gave you. The distributor toggled the 5 volts right? Ok so this signal goes to the MPI control unit which in turn supplies a small voltage the the base of a NPN transistor in the power module. You state that when you performed the transistor test, the coil fired. That means the power transistor and coil are good. Your problem is either in the wiring from dist.to the MPI or MPI to power transistor or simply a bad MPI control unit. A am basing this on what your test results. Good luck
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: No Fire, ( all of a sudden???) [Re: conner] #587399 04/07/05 03:11 PM
Well, I guess that's all I have left
I received the transistor and it did not help.
If it is the MPI unit, wouldn't it give me some
kind of code, besides "normal state" code? <img src="/forums/images/graemlins/frown.gif" alt="" />
I will chase wires now. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: No Fire, ( all of a sudden???) #587400 04/07/05 08:59 PM
Mendel Offline
I haven't read this thread thoroughly but has anyone suggested the ECU aka the computer?
1991 Montero LS, fading red paint
Front and rear limited slip differentials
95 SR Rear Springs, torsion bar crank, 137,650 miles
33x12.5 ProComp Mud Terrains, Bushwacker Fender flares
3 litre V6 with new heads
Re: No Fire, ( all of a sudden???) [Re: Mendel] #587401 04/08/05 01:20 AM
Thanks, I'm looking for one now.
Re: No Fire, ( all of a sudden???) [Re: FrankR] #587402 04/08/05 04:54 AM
Jake97T Offline
I didnt read the entire reply thread, but check the ingition fuse, sometimes the connectors can get too wide so it gets a bad connection, especially if youve got accessories jerry rig tied up around that fuse.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6311 MB (Peak: 0.7367 MB) Data Comp: Off Server Time: 2026-06-07 08:26:05 UTC
