Rear window wont roll down.
#588848
04/05/05 12:57 AM
I'm sure (hope) that this is a fuse. Where is the fuse for the rear window located? Thanks alot, any other thoughts are most welcome. Matt <img src="/forums/images/graemlins/confused.gif" alt="" />
1992 4Runner V6 SR5 4x4 Auto -ARBequed, Geared, Lifted, Lighted, and Locked. 32 BFG KM's
Re: Rear window wont roll down.
[Re: SWORDFISH92]
#588849
04/05/05 05:23 PM
Toyota Section Staffer
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
[Re: Red_Chili]
#588850
04/05/05 07:02 PM
I've noticed that if the rear window goes down with the interior switch, but not the key, that my license plate lamps are burned out. Yes, both. I've got some wierd occasional short knocking them out. New lamps, key is operational. I'm sure it's just me though. 4Crawlers information is priceless. That's where I always go first. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: SWORDFISH92]
#588851
04/05/05 07:06 PM
Before you go to a lot of trouble, make sure the rear wiper is parked all the way <img src="/forums/images/graemlins/smile.gif" alt="" /> If it's not the window won't do anything.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 - '84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
[Re: Staceman]
#588852
04/05/05 07:54 PM
I've noticed that if the rear window goes down with the interior switch, but not the key, that my license plate lamps are burned out. Yes, both. I've got some wierd occasional short knocking them out. New lamps, key is operational. I'm sure it's just me though. 4Crawlers information is priceless. That's where I always go first. <img src="/forums/images/graemlins/kewl.gif" alt="" /> The tailgate harness is a weak point. Mine had broken wires. The PO had 'fixed' them with crimp lugs, which filled up with moisture, turned to cupric sulfate, and disintegrated. Simple fix with solder, shrink tube, fresh wire, and tape, but tedious to track down.
[Re: Red_Chili]
#588853
04/05/05 07:57 PM
Yeah, I noticed that Bill. My tailgate is missing the grommet where the wire assy. enters the tailgate. It's all taped up with elictrical tape. I'm kinda afraid to start removing it if you know what I mean!
[Re: Staceman]
#588854
04/05/05 08:39 PM
<img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> Sometimes, all that's LEFT is the baling wire!
[Re: fourwd1]
#588855
04/05/05 08:40 PM
Thanks for the info guys, turns out that the rear wiper wasnt completely seated and was ajar after all.
Again, Thanks alot for the help. Matt <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: SWORDFISH92]
#588856
04/05/05 09:02 PM
Thanks for the info guys, turns out that the rear wiper wasnt completely seated and was ajar after all. #1 most common problem I list on the rear window page: http://www.4crawler.com/4x4/CheapTricks/RearWindow.shtml#TroubleshootingSo what are the most common problems that are encountered with the rear window? #1 is the rear wiper not fully retracting and closing its switch. If the window relay doesn't think the wiper is off the glass, it won't move the window, up or down. In the 1st gen 4Runner you can also have neglected to reconnect the window wiper connector inside the rear driver's side corner.
[Re: SWORDFISH92]
#588857
04/05/05 11:10 PM
Thanks for the info guys, turns out that the rear wiper wasnt completely seated and was ajar after all. I love the simple and cheap fixes. Gotta remember that the rear wiper assy is hitting 20 years old! <img src="/forums/images/graemlins/wink.gif" alt="" />
