Rear window wont roll down. #588848 04/05/05 12:57 AM
SWORDFISH92 Offline OP
I'm sure (hope) that this is a fuse. Where is the fuse for the rear window located? Thanks alot, any other thoughts are most welcome.
Matt <img src="/forums/images/graemlins/confused.gif" alt="" />
1992 4Runner V6 SR5 4x4 Auto
-ARBequed, Geared, Lifted, Lighted, and Locked. 32 BFG KM's
Re: Rear window wont roll down. [Re: SWORDFISH92] #588849 04/05/05 05:23 PM
Red_Chili Offline
Toyota Section Staffer
-Bill
Re: Rear window wont roll down. [Re: Red_Chili] #588850 04/05/05 07:02 PM
Staceman Offline
I've noticed that if the rear window goes down with the interior switch, but not the key, that my license plate lamps are burned out. Yes, both. I've got some wierd occasional short knocking them out. New lamps, key is operational. I'm sure it's just me though. 4Crawlers information is priceless. That's where I always go first. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Rear window wont roll down. [Re: SWORDFISH92] #588851 04/05/05 07:06 PM
fourwd1 Offline
Before you go to a lot of trouble, make sure the rear wiper is parked all the way <img src="/forums/images/graemlins/smile.gif" alt="" /> If it's not the window won't do anything.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Rear window wont roll down. [Re: Staceman] #588852 04/05/05 07:54 PM
Red_Chili Offline
The tailgate harness is a weak point. Mine had broken wires. The PO had 'fixed' them with crimp lugs, which filled up with moisture, turned to cupric sulfate, and disintegrated. Simple fix with solder, shrink tube, fresh wire, and tape, but tedious to track down.
-Bill
Re: Rear window wont roll down. [Re: Red_Chili] #588853 04/05/05 07:57 PM
Staceman Offline
Yeah, I noticed that Bill. My tailgate is missing the grommet where the wire assy. enters the tailgate. It's all taped up with elictrical tape. I'm kinda afraid to start removing it if you know what I mean!
Re: Rear window wont roll down. [Re: Staceman] #588854 04/05/05 08:39 PM
Red_Chili Offline
<img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
Sometimes, all that's LEFT is the baling wire!
-Bill
Re: Rear window wont roll down. [Re: fourwd1] #588855 04/05/05 08:40 PM
Thanks for the info guys, turns out that the rear wiper wasnt completely seated and was ajar after all.
Again, Thanks alot for the help.
Matt <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Rear window wont roll down. [Re: SWORDFISH92] #588856 04/05/05 09:02 PM
4Crawler Offline
#1 most common problem I list on the rear window page:
http://www.4crawler.com/4x4/CheapTricks/RearWindow.shtml#Troubleshooting
So what are the most common problems that are encountered with the rear window?
#1 is the rear wiper not fully retracting and closing its switch. If the window relay doesn't think the wiper is off the glass, it won't move the window, up or down. In
the 1st gen 4Runner you can also have neglected to reconnect the window wiper connector inside the rear driver's side corner.
Re: Rear window wont roll down. [Re: SWORDFISH92] #588857 04/05/05 11:10 PM
Staceman Offline
I love the simple and cheap fixes. Gotta remember that the rear wiper assy is hitting 20 years old! <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6471 MB (Peak: 0.7682 MB) Data Comp: Off Server Time: 2026-06-17 11:42:47 UTC
