Page 5 of 6 1 2 3 4 5 6
Re: Rear bumper project/ plans... [Re: onebadtrooper] #589055 04/22/05 03:13 PM
dvtrooper Offline
Very nice work looks great. Keep up the good work. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Don
sua dana 44 conversion 5.38 gears, 4.3tbi,700r,dana 300 w/tera low 4:1 gears
Re: Rear bumper project/ plans... [Re: dvtrooper] #589056 04/22/05 06:13 PM
onebadtrooper Offline OP
Hey thanks guy's. It weighs 93lbs <img src="/forums/images/graemlins/shiner.gif" alt="" /> Theres six 1/2" grade 8 bolts, and two stock smaller size bolts. On the sides I drilled out the two outer factory bolt holes, and welded in a nut on the in side of the frame. so I now have two 1/2" standard bolts on the sides <img src="/forums/images/graemlins/smile.gif" alt="" />. I'm going to have to get a big drop down hitch, if i'm ever going to tow anything. Thanks for all the comments <img src="/forums/images/graemlins/cheers.gif" alt="" />.
And kevin, We can probably do something with that bumper you have, last time we didn't have much time. I'm sure we can make it alittle less <img src="/forums/images/graemlins/shiner.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" /> you now.
Re: Rear bumper project/ plans... [Re: onebadtrooper] #589057 04/22/05 07:23 PM
F
Frisky Offline
I am gonna see if I can manage to cut the bull bar part off and get the c-channel section mounted where I want it first off and then work from there. I will let you know though
1992 Isuzu Rodeo 2WD (some assembly required). "If it doesn't fit....Force it!! If it breaks, it needed to be replaced anyway."
Re: Rear bumper project/ plans... [Re: Frisky] #589058 04/22/05 07:49 PM
matthew Offline
lots of work...........and it came together very nicely.
good looking finished product <img src="/forums/images/graemlins/cheers.gif" alt="" />
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: Rear bumper project/ plans... [Re: matthew] #589059 04/22/05 08:07 PM
G
GKreamer Offline
Man, that is one sweet bumper! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Time for you to update your sig line to reflect your hard work!
Re: Rear bumper project/ plans... [Re: GKreamer] #589060 04/23/05 08:52 AM
i was gonna say the same thing!!
nice work man, very nice!!!!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Rear bumper project/ plans... [Re: onebadtrooper] #589061 04/23/05 01:45 PM
JAVYPRO Offline
_Chris <img src="/forums/images/graemlins/patriot.gif" alt="" />
Hello to the Trooper gang. I am not an Isuzu but Mitsubishi owner and while surfing through your section I came across this post and I have to say that this is one of the best rear bumper designs and finest work I have ever seen. The bumper follows the contour of the Trooper perfectly and at the same time offers great protection to the panel corners. It doesn't sacrifice the vehicle depart angle and your meticulous attention to support the bumper securely beats 100 to 1 some big bumper manufacturers. [color:"red"] GREAT JOB [/color] <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Rear bumper project/ plans... [Re: JAVYPRO] #589062 04/24/05 01:31 AM
TrooperJ Offline
As always, very very nice work. How you likin that duplicolor liner? I like it on my t-hitch, and it stands up pretty well to rocks <img src="/forums/images/graemlins/kewl.gif" alt="" />.
Again, great job
-J <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
Re: Rear bumper project/ plans... [Re: TrooperJ] #589063 04/24/05 04:28 AM
Thanks guy's. I like the bedliner, it turned out pretty good. And it only cost $15 to do it. Thanks for all the good commments <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Rear bumper project/ plans... [Re: onebadtrooper] #589064 04/25/05 02:35 AM
That seriously looks better than most of the store bought aftermarket bumper designs I've seen, regardless of what vehicle they were intended for. That is a very nice design, and from what I can see the finished product looks exceptional. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Swordyyy
PHP: 7.4.33 Page Time: 0.987s Queries: 16 (0.983s) Memory: 0.6432 MB (Peak: 0.7689 MB) Data Comp: Off Server Time: 2026-10-24 13:07:42 UTC
