getting ready to do the water pump #589120 04/05/05 01:17 PM
urso8up Offline OP
I am going to do the water pump on my 98 T100 I am going to do the timming belt also sinice i will be right there and i have 135k miles on my truck. Is there anything i need to know or do while i am in there???
Thanks
1998 T100 4x4 3 body lift 4 procomp suspension 15x10 steel wheels and 35x12.50x15 Baja Claws
http://www.cardomain.com/id/urso8up
Re: getting ready to do the water pump [Re: urso8up] #589121 04/05/05 02:22 PM
jmoser Offline
Cam and crank seals are a good idea at 135K.
Some folks check the valve clearances too.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: getting ready to do the water pump [Re: jmoser] #589122 04/06/05 01:19 AM
urso8up Offline OP
ok thanks will do it
Re: getting ready to do the water pump [Re: urso8up] #589123 04/08/05 04:54 AM
kewlynx Offline
Remember to turn on your heater and leave the radiator cap off to burp all the air out of the system when you reservice it also. USE DISTILLED WATER, not tap, to mix your 'freeze; less corrosion means minimizing head gasket trouble later on.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6036 MB (Peak: 0.6589 MB) Data Comp: Off Server Time: 2026-06-21 09:59:14 UTC
