can i get away with it #589300 04/05/05 11:45 PM
G
grifter679 Offline OP
i have a 92 montero sr, after reading about budget lifts i understand i will need to crank my t-bars, how ever after my father an i look ad my rear which sits fairly i high, i am wondering if i will need to raise the rear in order to fit a set of goodyear 285 75 r16 mtr
i am running 265 75 r15 allterrains righ now and i have lots of room between the top of my tire and my fender well to go bigger,
any suggestions?
thank you all very much
Re: can i get away with it [Re: grifter679] #589301 04/06/05 12:00 AM
Why would you go to a 16" wheel? Why not just get a set of 33x12.5x15's? We know they will work and are probably cheaper than any 16" tire.
Re: can i get away with it #589302 04/06/05 01:08 AM
DougH Offline
Mitsubishi Forum Moderator
In the future please use more descriptive titles in the future. I have to run, but I will try and comment on your question later.
DougH
1995 SR - RIP
1993 RS - RIP
Re: can i get away with it [Re: DougH] #589303 04/06/05 04:26 AM
G
sorry for the lack of a better title, the reason for the 16 inch rim is because my father wants to replace his mud terrains with all terrains on his f250. so rather than throw them away, he is going to give them to me to put on my montero, his wheels are 16 inches so that explains why i cant get 33" 75 r15 mtr's
i will include a picture to show the body clearance i have
Re: can i get away with it [Re: grifter679] #589304 04/06/05 04:37 AM
DougH Offline
If the bolt pattern on the wheels is the same then you need to measure the hubs and the wheel opening to see if they will fit. The montero's hubs are pretty big and the wheels might need some grinding, if they are even the right lug pattern.
DougH
1995 SR - RIP
1993 RS - RIP
Re: can i get away with it [Re: DougH] #589305 04/06/05 04:52 AM
Tycer Offline
If I understand you correctly you are going to try to use his rims also?? A F250 uses a 8bolt so It will not fit your truck. Maybe I just misunderstood you and you are just using his tires. Anyway. I have 285/75r16 Bridgestone MT's on my 89 montero and have the Tbars cranked and have no rubbing at all. Of course, I havent taken it on any serious off-road adventures yet. <img src="/forums/images/graemlins/frown.gif" alt="" />
[img]www.members.aol.com/tycer1184/Montero/sideview[/img]
* * MY 1993 JEEP GRAND CHEROKEE * * RockKrawler Long Arm Lift, 8" of total Lift, Garvin Wilderness Rack, Hella Lights, 285/75r16 Firestone Destination tires.
Re: can i get away with it [Re: Tycer] #589306 04/06/05 05:37 AM
G
no the rims will be replaced with 6 lug 16x8 wheels,
Re: can i get away with it [Re: grifter679] #589307 04/06/05 03:59 PM
ForcedAir_Montero Offline
I don't think you'll have a problem. I run 285/75/16s on my gen 1, but lots of guys around run 33x12.50x15 on gen2s.
The 285 is actually a little narrower than the 33x12.5, and width is usually where the problems start.
-Dave D
Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..."
-Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
Re: can i get away with it [Re: ForcedAir_Montero] #589308 04/06/05 10:08 PM
G
thanks for the replies, and im replacing im goa go ahead and replace the all the shocks since they are not quite upto standards
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.012s) Memory: 0.6265 MB (Peak: 0.7135 MB) Data Comp: Off Server Time: 2026-11-19 05:28:31 UTC
