1994 Amigo #589979 04/07/05 04:45 PM
Hallo,
do anybody know, wich rear axle is in a 1994 Amigo? The Diff. has 12 bolt holes!
Thank you
Roland
Re: 1994 Amigo #589980 04/07/05 05:00 PM
houlster Offline
Isuzu Moderator
It's an Isuzu 12 bolt. The bolts to count are the ring gear bolts. The 10-bolt front has 12 outer diff bolts as well I think.
--Dan
Re: 1994 Amigo #589981 04/07/05 07:09 PM
strawmyers Offline
Isuzu Moderator
If it has disc brakes, its an Isuzu 12 bolt (no relation to the GM axle). If it has drum brakes, its an Isuzu 10 bolt.
Sean Strawmyer
Re: 1994 Amigo [Re: strawmyers] #589982 04/07/05 07:18 PM
O
OffRodEO Offline
woa woa woa now guys, are you guys saying that he doesnt have a dana 44 like i do on my 93 rodeo?(lol i know what you said)
unless the 4 cyl is different im pretty sure he has a dana 44
kevan
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler
WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
Re: 1994 Amigo [Re: OffRodEO] #589983 04/07/05 07:45 PM
lttlbddy Offline
ALL 1st gen Amigos (1989-1994) have Isuzu rear end as stated above. SG
Re: 1994 Amigo [Re: OffRodEO] #589984 04/07/05 08:22 PM
strawmyers Offline
Isuzu Moderator
Nope. 1st gen Amigos and all Troopers were built in Japan and use Isuzu axles f/r. 2nd gen Amigos and all Rodeos were built in America and use either Dana or GM rear axles.
Sean Strawmyer
Re: 1994 Amigo [Re: strawmyers] #589985 04/07/05 08:40 PM
O
OffRodEO Offline
wow after 1 1/2 years on this website, i never new that. Thank you for clarifying that.
kevan
Re: 1994 Amigo [Re: strawmyers] #589986 04/07/05 10:29 PM
houlster Offline
Isuzu Moderator
I'll check when I get home, but I think for '94, the 10 bolt rear was dropped entirely. I know for sure in '94 all motors were 2.6, and I think all axles were the 12 bolts.
--Dan
Re: 1994 Amigo [Re: houlster] #589987 04/07/05 11:15 PM
ProBMXer1313 Offline
According to Matt's site:
AMIGO
1989-1994 2.6L 4 CYL
FRONT: ISUZU IFS 10 BOLT
REAR: ISUZU 12 BOLT (3RD MEMBER, DISK BRAKE) (4WD & 2WD XS)
REAR: 2WD NON XS MODEL û ISUZU 10 BOLT
http://www.independent4x.com/generic46.html
Any one wanting to know what axle they have, what lockers they can get or what gear ratios they can get should check there.
1998 Honda Passport EXL V6 3.2L Auto SOTF 4WD
3" Calmini Lift w/ HD Track Bar, 32x11.5-16 Super Swamper SX, Aisins
[color:"blue"]http://www.CarDomain.com/ID/ProBMXer1313[/color]
Re: 1994 Amigo [Re: houlster] #589988 04/07/05 11:30 PM
strawmyers Offline
Isuzu Moderator
If all motors were 2.6's in '94, then you are probably correct about them dropping the rear 10 bolt. My '93 2wd 2.3 Amigo had a rear 10 bolt... but it seems like they changed a lot of little things for the '94 model year.
Sean Strawmyer
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.010s) Memory: 0.6346 MB (Peak: 0.7582 MB) Data Comp: Off Server Time: 2026-07-14 21:45:54 UTC
