Clearwater cylinder head #590235 04/08/05 04:21 AM
steven c Offline OP
I recently purchased a cylinder head from clearwater cylinder heads in Florida. The head has a new casting. What i found peculiar is it uses coil type springs to keep the rocker arms positioned over the valve springs. The stock isuzu head use spring steel type keepers. I contacted clearwater and they told me, they use the coil springs because the oem are harder to find. I am kind of leary of this set up. Any input?
Re: Clearwater cylinder head [Re: steven c] #590236 04/08/05 05:52 AM
mlclark Offline
Isuzu Moderator
It's just another way to skin the cat. It is also the same method used by many other manufacturers who use overhead cams.
Michael
Re: Clearwater cylinder head [Re: steven c] #590237 04/08/05 06:03 PM
RSimister Offline
I bought a head 4ze1 from them with that set-up 50,000 km ago.Truck runs amazing,lower emissions on a drive clean test than my 2001 grand-prix.I've been looking for signs of wear on the rocker shaft when the valves get adjusted and nothing yet.Seems to work fine
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5930 MB (Peak: 0.6461 MB) Data Comp: Off Server Time: 2026-06-22 18:12:00 UTC
