Help! Valve cover corner cracked! #590388 04/08/05 06:48 PM
Nathan Offline OP
I have been noticing that I am starting to seep oil from the valve head covers gasket (both sides). I inspected each bolt to see if maybe over time some loosened a bit. Upon inspection of the drivers side (the oil fill side) noticed that the front corner of the valve head cover was a tad loose. I snugged it up (did not crank on it, but anyhoo)and heard a snap! The tab cracked <img src="/forums/images/graemlins/frown.gif" alt="" /> What are my options at this point? Can it be remedied in place. Do I have to get a new valve head cover ($$$)? Ideas welcomed, but please be kind as I already feel like a jerkoff and I cannot kickmyself any harder. Thanks Fellas
1996 T100 Ext Cab 4x4 W/165k
AMSOIL Throughout
Re: Help! Valve cover corner cracked! [Re: Nathan] #590389 04/08/05 07:10 PM
jmoser Offline
If you can degrease it thoroughly you may be able to get away with Silicon Gasket Maker and / or JB Weld, etc.
Depending on the size of the crack you may have to remove the cover first and put the bead down thick, a minor crack you may be able to patch from the outside. Remember you are not holding against pressure, just need to make a barrier.
There is always duct tape too! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5875 MB (Peak: 0.6357 MB) Data Comp: Off Server Time: 2026-06-17 11:30:59 UTC
