Page 1 of 3 1 2 3
rear springs on front and 63" chevys #590635 04/09/05 08:06 PM
SHAD Offline OP
Well I got the stuff I need to do it from Bud Built.
Bud Built Boomerang shackles and chevy leaf hangers with skidplates
Should I get some ford F250 shock towers too and get longer shocks for the front?
I was also thinking about the rear my shocks already mount like this in the rear / \ However the bottom part of the shock attaches to the bottom of the u-bolt plates. I was thinking of getting some new u-bolts and putting the bottom plate on top and using the existing shock mounts on the plates with longer shocks would that work?
Now the only thing I have to do is track down my rear 63" springs for a decent price.
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: rear springs on front and 63" chevys [Re: SHAD] #590636 04/09/05 08:33 PM
Creeper Offline
Keep getting hooked up from Bud - BudBuilt Shock Mounts
Your truck is really starting to come together - <img src="/forums/images/graemlins/kewl.gif" alt="" />
'97 T100 SR5 XCab 4WD
TRD SC ~ ARB ~ FWC
'85 FJ60 Landcruiser
4E9 ~ locked ~ 33's
Re: rear springs on front and 63" chevys [Re: Creeper] #590637 04/09/05 11:09 PM
hunterp Offline
rathe's quoted me 70 bucks for 3/4 ton 56" chevys.
i bet baileys spring and chassis has some lying around though..
85 4runner/duals/detroits f&r/5.29s/winch/stuff
Re: rear springs on front and 63" chevys [Re: SHAD] #590638 04/10/05 03:09 AM
missouriman Offline
post up as you do this please, I am thinking of doing the same thing.
Re: rear springs on front and 63" chevys [Re: SHAD] #590639 04/10/05 03:10 AM
missouriman Offline
oh,, post up about the steering setup you are using.
Re: rear springs on front and 63" chevys [Re: missouriman] #590640 04/10/05 03:30 AM
ChrisH Offline
Every time I've called bailey's on spring prices I walk away going <img src="/forums/images/graemlins/zombie.gif" alt="" />
Don't get me wrong, they do awesome work there, and John Drinkwine is a great friend of mine <img src="/forums/images/graemlins/kewl.gif" alt="" />
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: rear springs on front and 63" chevys [Re: SHAD] #590641 04/11/05 06:05 PM
fourwd1 Offline
You'll need longer shocks to handdle the increased travel, and the Ford towers are easy and cheap.
A u-bolt flip is good in the back and necessary in the front (cause of the x-over steering). The shocks work better when like this | | but you can use a longer shock this way / \.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: rear springs on front and 63" chevys [Re: SHAD] #590642 04/11/05 08:34 PM
Toughguy Offline
I got my 63" Chevy`s from a guy parting out an `89 1/2ton pickup. For $50 I had to take them off myself so i torched the mounts right off the frame. Worked out good because I modded the stock chevy mount with some plate steel that was lying around. For the rear I used the stock chevy shackle and just made my own mount out of angle iron.
For the front I used the Ford mounts an they work great with Rancho 5012s or 9012s.
It`s just roughed-in there for fitment. For my truck, the bottom of the mount needed to be flush with the top of the frame.
I used the factory shock mount on the axle for the lower.
For the rear I chose the same Rancho 5012s that I have up front but they are so long that I needed to fab a new upper mount. Even with a 2" BL, the lower shock mount is almost in the stock location and not on top of the axle where I really wanted it.
Yeah it looks very bootyfab but it works fine and was super cheap to make.
Toughguy <img src="/forums/images/graemlins/notooth.gif" alt="" />
Roads? Where I`m going, I don`t need roads!
Re: rear springs on front and 63" chevys [Re: Toughguy] #590643 04/11/05 09:46 PM
SHAD Offline OP
The hysteer I will be using is the sky-manufacturing setup. I bought it from www.roadessgear for $413 shipped.
It's hard to find these 63" springs for cheap I am shopping around but haven't found any for a good price yet rathe's claimed they didn't have any. I have to go up there and make sure tomorrow.
86 Toyota 4 runner
My cardomain page
Re: rear springs on front and 63" chevys [Re: SHAD] #590644 04/11/05 10:00 PM
ChrisH Offline
Shad, I know it's an hour away, but these're the prices around here:
Bailey's in Barre: $165.00 per side new
Bettis Autoland in Rochester: $120.00 per pair and they cut the shackles cuz they're lazy
Allen Auto in Chelsea: $100.00 for a pair of 98 4wd. Not sure if he'll charge less for the 2wd or older, you could probably dicker with him some.
That's all that I called, I was content driving 20 minutes to get that pair for 100 bucks. Don't steal it <img src="/forums/images/graemlins/lol.gif" alt="" />
I'm headed over there on saturday, I can ask him what his bottom price is for an older 2wd(then you can dicker from there hehe) if you want.
<img src="/forums/images/graemlins/cheers.gif" alt="" /> -Chris
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6450 MB (Peak: 0.7678 MB) Data Comp: Off Server Time: 2026-06-17 03:34:38 UTC
