Page 2 of 3 1 2 3
Re: 1" body lift installed on 2nd gen trooper! [Re: Wareagle] #590729 04/11/05 06:03 AM
Bansil Offline
Mark,
WoW <img src="/forums/images/graemlins/cheers.gif" alt="" /> what a big difference.....that thing looks like a monster now......was surprised......big difference
from when i saw it in WV <img src="/forums/images/graemlins/kewl.gif" alt="" />
Good job
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: 1" body lift installed on 2nd gen trooper! [Re: Wareagle] #590730 07/07/05 02:31 PM
LSGA Offline
To save some $$, I used 4 large and 8 mini "pucks"
FYI: Just picked this up from 4WP for $17.XX shipped to GA... great time to get some if interested! Hehe, quick thread revival (from Warsaw, Poland might I add <img src="/forums/images/graemlins/smile.gif" alt="" /> - something fun to come home to in a week)
1996 Isuzu Trooper LS, 33" BFG KMs, ARB Bullbar, OME 919's + 2.5" Daystar Spacers, RS5000's (Nissan Patrol's in the rear), DOR Bumpstops, K&N cone, Aisin manuals, factory LSD. oh, and a ton of N.E. rust <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 1" body lift installed on 2nd gen trooper! [Re: LSGA] #590731 10/18/05 04:48 PM
LSGA Offline
This is a generic question: for those who have done a 1" Bl on either a Rodeo or Trooper, did you unbolt the fan shroud or do anything with the radiator?
I'm pieceing together the step by step process from a few articles online as well as previous posts in this forum, but just wanted to get the final OK from a few 4x4wire members.
Thanks y'all,
Santi
Re: 1" body lift installed on 2nd gen trooper! [Re: LSGA] #590732 10/18/05 06:12 PM
strawmyers Offline
Isuzu Moderator
How about on an Amigo <img src="/forums/images/graemlins/wink.gif" alt="" /> I removed the radiator and drilled new mounting holes in it 1.25" higher than the original holes (my BL is 1.25"... obviously you'll want to measure down 1" for yours). There was no metal to move the upper hole higher on the passenger's side of the radiator, so it only has one bolt holding that side in place. But, between the two bolts on the driver's side and the one on the passenger's side, its not going anywhere. Had to do some minor trimming on the fan shroud as well, but nothing major.
Sean Strawmyer
Re: 1" body lift installed on 2nd gen trooper! [Re: LSGA] #590733 10/18/05 11:23 PM
Sfinx Offline
LSGA, just saw your answer, are you Polish, or were you just traveling out there?
The mighty oak tree was once a little nut that held its ground.
2000 Trooper LS with TOD
ARB bumper, custom roof rack, 33" BFGoodrich AT, K&N, OME springs, Aisin hubs, Rancho 9000, WARN XD9000, Maxi-Kool Tranny Cooler, Optima Red,
Re: 1" body lift installed on 2nd gen trooper! [Re: Sfinx] #590734 10/18/05 11:52 PM
LSGA Offline
no, unfortunately im not polish (i loved warsaw) - i was visiting the visegrad countries as a part of a study abroad focusing on the EU.
Re: 1" body lift installed on 2nd gen trooper! [Re: LSGA] #590735 10/19/05 02:20 AM
W
Wareagle Offline OP
No, I just added the pucks, I did not extend and hoses or anything. I did have a minor coolant leak near heater area for a day or two, but it healed itself.
Re: 1" body lift installed on 2nd gen trooper! [Re: Wareagle] #590736 10/19/05 03:11 AM
Starchild Offline
I did a one inch and never bothered with the fan shroud at all. No problems to report.
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: 1" body lift installed on 2nd gen trooper! [Re: Starchild] #590737 10/19/05 12:59 PM
Nick Offline
When I did the 1" BL on my 99,I was looking into doing 1.5"-2". I couldn't find any of the metric fine thread that would be long enough for the rear captive bolts. The stock front bolts should work fine in the rear up to a 1.25" BL. On my 87 trooper 1" BL, I reused the front bolts, but was 2 bolts short. I made some using althread and with two nuts with the outer one weld to the althread and the inner one to act as a jam nut.
'99 Trooper 3.5L->R150F->Duals->4.7->60/14b->38.5s
'96 Trooper DD
Re: 1" body lift installed on 2nd gen trooper! [Re: Nick] #590738 10/19/05 05:37 PM
Jonesy Offline
I did a full 3" on my Rodeo and left the rad in place...so far no problems after 2 years. I did remove the bottom protion of the shroud to keep it from interfering. I just readjusted the tubes to the radiator and never had coolant leaks or anything.
Steve
'97 Rodeo
3.2L V6
DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6410 MB (Peak: 0.7660 MB) Data Comp: Off Server Time: 2026-07-15 13:30:02 UTC
