Page 3 of 3 1 2 3
Re: 1" body lift installed on 2nd gen trooper! [Re: Wareagle] #590739 03/02/06 04:05 PM
2000Trooper Offline
In the front six mounts, I bought 7/16 x 6" grade 5 bolts from Tractor supply for the $4. These are a little beefier than stock, but fit perfect.
Do you know if 1/2 x 6" bolts will fit in the front six mounts? These are also grade 5 bolts.
Thanks
Jaime
Re: 1" body lift installed on 2nd gen trooper! [Re: 2000Trooper] #590740 03/02/06 06:09 PM
would it be wise to buy larger bolts and maybe drill out larger holes to allow for strength? just a thought--i was pondering.
i like the idea of a 1" body lift. especially if you don't have to do any other work. (trans linkage, steering linkages, hoses, etc.) <img src="/forums/images/graemlins/baby.gif" alt="" />
then i can go get a susp lift!!! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: 1" body lift installed on 2nd gen trooper! #590741 03/03/06 05:04 PM
BajaZu Offline
So what was the finally count of pucks needed for the BL, and does anyone know what the stock size mounts that are used on the 2nd gen trooper are?
Re: 1" body lift installed on 2nd gen trooper! [Re: BajaZu] #590742 03/03/06 06:01 PM
2000Trooper Offline
Here is the number of pucks from Wareagle's Post:
First, you'll need:
*12(twelve) "pucks" or "mounts"
*6(six) Grade 5 nuts and bolts (options below)
To save some $$, I used 4 large and 8 mini (pucks)
Here is a picture to help you plan your lift:
Jaime
Re: 1" body lift installed on 2nd gen trooper! [Re: BajaZu] #590743 03/04/06 12:14 AM
Y
ybnormal70 Offline
Ok, I'm a little confused here. You said you need 12 pucks and one post says 16. The picture posted only seems to show 10. What am I missing here? I have a 94 Trooper and would like to do a 1" BL on. Where is the cheapest place to buy the 1" pucks and exactly how many would I need of each size?
Thanks,
Kevin
'94 Trooper S 3.2SOHC, 5spd, Aisin hubs, OME919 w/ 2" coil spacers, Edelbrock shocks, fliped BJ's and spacers, 15" snowflakes w/33x12.50x15
Re: 1" body lift installed on 2nd gen trooper! [Re: ybnormal70] #590744 03/04/06 01:02 AM
W
Wareagle Offline OP
Follow my directions at the top. They list what you need. You cna get the individual pucks from most offroad shops. They are called "replacements".
Re: 1" body lift installed on 2nd gen trooper! [Re: ybnormal70] #590745 03/04/06 01:04 AM
2000Trooper Offline
If you look at the image, 5 and 6 are very close together. So you have 6 on each side. Thats gives you a total of 12.
Jaime
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.007s) Memory: 0.6200 MB (Peak: 0.7138 MB) Data Comp: Off Server Time: 2026-11-01 22:23:27 UTC
