Independent 4X Extended Brake Lines #590807 04/10/05 06:35 AM
ckimbrough18 Offline OP
I finally got my truck fixed. It has been broke down for the past 3 months needing a new clutch slave cyl. So now I was able to install my Christmas present to myself. New extended brake lines for the rear! These things are NICE. Actually, I had the garage install them while they put a new inspection sticker on it. The mechanic saw the new lines and was real impressed with the quality.
I did'nt do the front yet because of my plans to SAS in the near future. But will be installing the same lines up front at that time. My stock brake lines were getting dry rotted and needed to be just a little longer. I'm running 2" springs in the rear.
As far as I can tell. The brake pedal only feels about half as spongy as they did. I'm sure that after the front in installed, that the spongy feeling will completely be gone. Here are a few pics of the rear.
[Linked Image] \\
Re: Independent 4X Extended Brake Lines [Re: ckimbrough18] #590808 04/11/05 06:15 PM
paulevans76 Offline
Cool. I'm close to doing a full brake job on my piece, and with the stockers at almost 18 years old, I'm thinking about giving these lines a shot. <img src="/forums/images/graemlins/wink.gif" alt="" />
BTW something wierd about the pics, I had to cut and paste the html from each one and come back to the thread to see them <img src="/forums/images/graemlins/confused.gif" alt="" />
88 Troop - Posing yard art
Re: Independent 4X Extended Brake Lines [Re: paulevans76] #590809 04/11/05 06:56 PM
strawmyers Offline
Isuzu Moderator
That is because he is hosting them via Webshots. They don't allow external linking of pics.
Sean Strawmyer
Re: Independent 4X Extended Brake Lines [Re: strawmyers] #590810 04/11/05 07:12 PM
Smiley Offline
How odd... I can see them just fine.
Look'n good, Charles! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Cheers! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Smiley
Six Isuzus, so far... still have three of them.
Re: Independent 4X Extended Brake Lines [Re: Smiley] #590811 04/11/05 09:14 PM
I installed these very lines on my 2001 Rodeo last week. They are great!
Re: Independent 4X Extended Brake Lines [Re: Smiley] #590812 04/11/05 09:48 PM
W
Wayne Offline
I see them at home (zero firewall) not at work (corporate firewall)
Dan's engine change pics I see at both locations.
Re: Independent 4X Extended Brake Lines [Re: Wayne] #590813 04/11/05 10:06 PM
Thanks guys. It is weird. Sometimes they come up for me. Sometimes they don't. I thought since I am a premium member at webshots that it is alright to link them. I will have to check into that.
Trooper has been sold!
Re: Independent 4X Extended Brake Lines [Re: ckimbrough18] #590814 04/14/05 02:51 PM
matthew Offline
cool...........glad to see that you finally got them installed.
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: Independent 4X Extended Brake Lines [Re: matthew] #590815 04/14/05 04:21 PM
HCMP Offline
So these replace just the rubber lines or the hard lines on the rear axle as well?
-j
Re: Independent 4X Extended Brake Lines [Re: HCMP] #590816 04/14/05 05:31 PM
They replace the rubber lines at all four wheels plus the rubber line that is in the middle at the rear of the vehicle.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6369 MB (Peak: 0.7607 MB) Data Comp: Off Server Time: 2026-05-25 18:56:49 UTC
