cooling issues #591518 04/11/05 10:08 PM
OK, so my 95 taco with 116k is overheating...I swapped the thermostat last night, but it did not fix the problem.
The truck runs fine, but after about 5 miles on the road the thermostat goes way up, then back down...then bak up and down...and so on.
It never goes into the red, but it gets really close...
any ideas on what the problem might be?
Re: cooling issues #591519 04/11/05 11:11 PM
are you sure 85 or 95
if its an 85 then the head gasket is blown
if you drain your oil i bet you will have coolent in there
my dad has an 85 with the 22re and it did the exact same thing you just described and there was a crack in the hg in the water jacket and the number 4 piston
oh yeah if it is an 85 it is not a tacoma it is just a pickup
Re: cooling issues #591520 04/12/05 04:31 AM
triniphen Offline
check the fan clutch. does it heat up when you sit still and cool off when your driving?
Re: cooling issues #591521 04/13/05 12:51 AM
Stan_Marshall Offline
if it really is an 85 and you have the 4 banger, it sounds like it might be temperature overshoot...
see here to read all about it.
1994 4x4 22RE W56 truck
Re: cooling issues #591522 04/13/05 03:29 PM
mt_goat Offline
If you have an 85 pickup let me show you the best 4x4Wire forum to post questions at: http://www.4x4wire.com/forums/postlist.php?Cat=&Board=UBB11
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: cooling issues #591523 04/14/05 10:59 PM
bump...its a 95'.
Re: cooling issues #591524 04/15/05 01:46 AM
P
pburruel Offline
I had a 86 Toyota. I started running a little hotter. I went to a radiaror shop and had the radiator cleaned and it started running normal again.
Re: cooling issues [Re: pburruel] #591525 04/15/05 02:01 AM
what engine?????
Re: cooling issues #591526 04/18/05 10:20 PM
2.7l
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6141 MB (Peak: 0.6985 MB) Data Comp: Off Server Time: 2026-06-20 21:35:53 UTC
