tps senor humming #593213 04/17/05 02:09 AM
slick8up Offline OP
i got a 1994 jeep with a 2.5 was driving down road and started to act like running out of gas did a hillbilly way of checking for fuel stuck knife in port on fuel rail fuel there "sprayed out" then got to checking tps sounds like it humming or clicking with the key on.
yes the gas tank is full fill yesterday
bad tps or ???? any clues <img src="/forums/images/graemlins/patriot.gif" alt="" />
94 jeep 3.5 lift 4.56s gears 33/12.5s geolanders mt locked rear warn 8000 and a 4 banger 4 power
Re: tps senor humming [Re: slick8up] #593214 04/17/05 02:13 AM
the TPS is humming? Do you mean IAC? If a TPS makes noise it is bad.
Did you check for engine codes?
Re: tps senor humming [Re: slick8up] #593215 04/17/05 02:15 AM
slick8up Offline OP
just making a lite humming nosie you can here it standing on the ground then you take hose off louder
what is a IAC
Re: tps senor humming [Re: slick8up] #593216 04/17/05 02:56 AM
The hose on the TPS??? WHA?? There is no TPS hose.
IAC motor, it is what does the idle...
Re: tps senor humming #593217 04/17/05 05:58 AM
slick8up Offline OP
i said that wrong i meant the air i meant the air breather hose
but heres whats not right went back about 1 hour later started right up
Re: tps senor humming [Re: slick8up] #593218 04/18/05 04:18 AM
BigJim Offline
Replace the fuel filter if it does it again...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6068 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-06-10 06:28:54 UTC
