tps senor humming
#593213
04/17/05 02:09 AM
i got a 1994 jeep with a 2.5 was driving down road and started to act like running out of gas did a hillbilly way of checking for fuel stuck knife in port on fuel rail fuel there "sprayed out" then got to checking tps sounds like it humming or clicking with the key on. yes the gas tank is full fill yesterday bad tps or ???? any clues <img src="/forums/images/graemlins/patriot.gif" alt="" />
94 jeep 3.5 lift 4.56s gears 33/12.5s geolanders mt locked rear warn 8000 and a 4 banger 4 power
Re: tps senor humming
[Re: slick8up]
#593214
04/17/05 02:13 AM
the TPS is humming? Do you mean IAC? If a TPS makes noise it is bad. Did you check for engine codes?
[Re: slick8up]
#593215
04/17/05 02:15 AM
just making a lite humming nosie you can here it standing on the ground then you take hose off louder
what is a IAC
[Re: slick8up]
#593216
04/17/05 02:56 AM
The hose on the TPS??? WHA?? There is no TPS hose.
IAC motor, it is what does the idle...
#593217
04/17/05 05:58 AM
i said that wrong i meant the air i meant the air breather hose but heres whats not right went back about 1 hour later started right up
[Re: slick8up]
#593218
04/18/05 04:18 AM
Replace the fuel filter if it does it again... Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6090 MB (Peak: 0.6735 MB) Data Comp: Off Server Time: 2026-06-07 09:41:44 UTCValid HTML 5 and Valid CSS
