Adding Daytime Running Lights to 2001 Trooper - Possible? #593462 04/17/05 07:09 PM
8
88_Super_Trooper Offline OP
I know that some people like DRL's and some don't. I like them and I want them. That being said, has anyone installed them on a late model Trooper? I have found several aftermarket "kits" that work in a variety of ways. Some turn on the low-beams and some turn on the high-beams, both at a reduced rate. Some also turn on tail lights and some have a delay that turns the lights on several seconds after the engine has started. Several web sites say that GM has a retrofit kit that will work on "most" vehicles. I can not find this "kit" available anywhere. I talked to the GM parts guy at the dealership and he was completely stumped. He could not comprehend what I was looking for. Perhaps some of the Canadian members might know a part # or have some useful information to add since these vehicles were sold in Canada and DRLÆs are required equipment. Any help or testimonials would be greatly appreciated. Thanks in advance.
You wouldn?t worry what people thought about you if you realized how little they did!
1988 Isuzu Trooper Limited, Bone Stock, 2.6L, 5 speed manual trany.
2001 Isuzu Trooper Limited, Bone Stock, 3.5L, Automatic.
Re: Adding Daytime Running Lights to 2001 Trooper - Possible? [Re: 88_Super_Trooper] #593463 04/17/05 11:23 PM
litnin Offline
You could wire it up fairly easy.
Tap in to your ignition "ON" wire that's only hot when the ignition is in the ON position. Use that tap to trip a relay that draws battery power and sends it to either the high or low beam of your headlights...whichever one you want to run as a DRL.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Adding Daytime Running Lights to 2001 Trooper - Possible? [Re: 88_Super_Trooper] #593464 04/18/05 03:04 PM
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.5941 MB (Peak: 0.6494 MB) Data Comp: Off Server Time: 2026-11-18 03:20:58 UTC
