33 x 10.5's on a stock 1990? #593650 04/18/05 04:38 AM
I have seen a few websites saying that a 33 inch tire can't be fitted to a stock 1990 4Runner (without rubbing), but these either fail to mention the tire width or they specify a 12.5" wide tire. I was wondering if anyone has tried to fit a 33 x 10.5 to a stock 4Runner. This is mostly my woods truck, mud and sand will be all I am seeing and an extra inch of clearance would help a lot.
Can anyone offer some guidance? Thanks, Mike
Re: 33 x 10.5's on a stock 1990? #593651 04/19/05 04:19 AM
jcssurf Offline
Stick to your stock wheels and they shouldn't be hard to fit at all. There is tons of stupid plastic in the wheel wells you can trim away, then metal you can bang or cut away if you have to.
I run 32x11.50s on 15x7's with 3.75" backspace with no lift and some simple trimming. I would think 33x10.50s would be as easy to clear (I wish I had them instead).
If they don't fit or you don't want to trim much, throw a 1" bodylift on from Roger Brown.
90 pickup, 22RE, stiff-ass Ranchos, 2.25 catback, 4:1 header, conical intake, 15x7 ICW alloys, 32x11.50 Dunlop Mud Rovers, 4.56s w/v6 rear
-Farm truck until school is done...then plans
2000 Honda CRV EX 5 speed
-Driver
Re: 33 x 10.5's on a stock 1990? [Re: jcssurf] #593652 04/19/05 04:46 AM
Thanks for the info. My other thoughts were a 32x10.5 or 32x11.5, so I am glad to see your comment about wishing you had the 33's. That makes me think I am heading in the right direction...
BTW, you mention backspacing. Is that the distance from a wheel's mounting surface (on the hub) to the edge of the rim?
I will have to check out the body list, too. Easy to install?
Thanks,
Mike
Re: 33 x 10.5's on a stock 1990? #593653 04/19/05 09:42 PM
jcssurf Offline
Yeah you are right on Backspace...
Your stock wheels are probably between 4.5 and 5 inches...which means the wheels sit closer in. As you start to decrease backspacing they stick out more and are more likely to rub the wheel well.
A body lift, especially the 1", is not a hard install. All you really need are some sockets, a block of wood, and a jack.
I don't know how bad your 4runner is sagging in the rear (like many are) but if you spend any money on lift you might want to put a small spacer back there to level it out.
-Driver
Re: 33 x 10.5's on a stock 1990? [Re: jcssurf] #593654 05/01/05 03:18 AM
Thanks again for the info, especially on the 1" list. It looks like I may have to do that.
Re: 33 x 10.5's on a stock 1990? #593655 05/04/05 06:20 AM
larsdennert Offline
33x9.5 doesn't rub and 10.5 rubs a bit. Mostly the inside rear of the front fender.
Re: 33 x 10.5's on a stock 1990? #593656 05/10/05 04:07 AM
byron4 Offline
if you could sling the money you could do ball joint spacers and new coils in the rear. it is a relitivily easy lift(i hear) and isnt overly expencive, roughly $400 it is good for about 2 inchs and can easily clear 33's and it will give you more suspension travel. i will be doing this soon to my 93.
Re: 33 x 10.5's on a stock 1990? #593657 05/10/05 08:30 PM
mattikeranen Offline
Like the others said: they?ll rub a little with original wheels. Remove mud flap and they don?t rub any longer at normal driving. Little pounding is necessary if you don?t want to get any rubbing at any circumstances. Check my photo (-94 with no lift and 33x10.50s): http://image44.webshots.com/44/4/34/94/300243494uONLSP_ph.jpg
And read this also: http://www.brian894x4.com/33INCHTIRES.html
4Runner 3.0 Turbo-Diesel, 2" suspension lift, 33x10.50R15 tires
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6163 MB (Peak: 0.7134 MB) Data Comp: Off Server Time: 2026-07-15 08:01:35 UTC
