shifting problems after change to Amsoil 75-90
#594504
04/19/05 09:26 PM
This is about a friends Tacoma 2002 V6 with 5 speed. He's got 30K miles on it and did a gear oil change from stock Toyota oil to the Amsoil 75-90. He's been driving for 2 days and reported very hard shifting almost grinding between shifts. When cold, 1st gear can only be selected when completely stopped. Before he could roll to a stop and already select 1st. The gearbox had no such symptoms up to the oil change. This behavior doesn't change much even when the truck has been driven for while and the oil is hot. He's a responsible driver (actually I'm not so sure about that)and takes care of his truck. Does anybody out there have similar experiences? Thanks for your input
92 Xcab V6 4x4 SR5 5sp., Detroit locker rear, lim. slip front, Warn hubs, H4's, electr. fan, eng. oil cooler, 1 lift, open cat.
Re: shifting problems after change to Amsoil 75-90
[Re: Eck]
#594505
04/19/05 10:04 PM
Former Admin
If it's GL-5, get it out of there asap. The GL-5 additives will eat the soft metal in the transmission (ie synchros).
Replace with a GL-4. I'd strongly recommend Redline MTL or MT-90.
[Re: little_joe]
#594506
04/19/05 10:28 PM
It is a GL-5 spec. The Toyota service manual states GL-5/ hypoid oil. How is it possible for the GL-5 to eat the syncros right after the fill and test drive? It shifted hard right immediately and didn't change much when warm.
[Re: Eck]
#594507
04/19/05 11:20 PM
It is a GL-5 spec. The Toyota service manual states GL-5/ hypoid oil. How is it possible for the GL-5 to eat the syncros right after the fill and test drive? It shifted hard right immediately and didn't change much when warm. My truck has been doing the same thing. Butter smooth until I changed it with 75-90 synthetic. Now first and second gear give me issues.. especially first.. I can feel it grind sometimes and I have to wait till it's at a complete stop when cold. Once warmed up, it is fine.. I dont know why..
[Re: little_joe]
#594509
04/20/05 03:34 AM
yeah, why in the heck toyota says you can run GL5 in your tranny is a mystery...definitely not good.
1994 4x4 22RE W56 truck
[Re: Stan_Marshall]
#594510
04/20/05 04:33 PM
Toyota Section Staffer
It's often mystified me as well - but I think the reason is, in dino oil GL-5 will work ok, won't eat the brass all that fast (if at all really), and is easier to stock at the dealers'. Stocking multi-grade oils is a high cost proposition. Don't we already complain about dealer costs passed on to the consumer?
The problem tends to emerge with synthetics. Watch and see if nearly every complaint occurs after someone goes synth, after running successfully for years on dino GL-5. Synths are more 'slippery'; the shear strength and lubricity prevent the synchros from grabbing the gear cones. Even some synthetic GL-4 oils are too slippery for the synchros, ask me how I know!
If going synth, by all means pay close attention to the grade: use GL-4 exclusively. Redline manual transmission gear lubes have proven highly successful in getting older trannies to shift like new. Better than new really, freshly rebuilt trannies often don't shift all that great until the synchros break in.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
[Re: Red_Chili]
#594511
04/22/05 05:41 PM
I checked out Amsoil's website.. it's wierd.. in one section it says to use GL-5 and a few lines below that it says GL-4.
#594512
04/22/05 06:20 PM
Wait till you read the owner's manual / FSM and it says either will work! Don't you believe it, at least when it comes to synthetics.
Ford friction modifier is reputed to work as well, but its stinky stuff and personally I would have an aversion to it...
[Re: Red_Chili]
#594513
04/23/05 01:25 AM
I think if you research more, you will find Amsoil is too slippery. I have had Redline MT90 in my 98 5spd now for 60k miles. Great. Also in my 88 5spd for 40k miles. Redline has something to help the snychros that Amsoil does not.
