Wondering what a fuse goes to.... #595099 04/21/05 05:35 PM
NCBBA2358 Offline OP
Pestering question....
91 yj 4.0
The MAXI fuse that is numbered "Fuse F2" under the hood is the only fuse that sparks a little when I pull it out meaning there is a closed circuit some place.... I can't figure out where it goes. The cover for the fuse block says "I.O.D." and I can't find it anywhere in the wiring diagrams in Chilton's book for this vehicle. What does this fuse protect? It is the fuse furtherest from the end and is one of the two 20 amp fuses on the line.
Only reason why I am wondering is that there seems to be a power loss in the system some place. First thing I looked at was the fuses. This is the only one that has current flowing through it (closed) all the time, but doesn't go to the lights/clock/radio backup....
Puzzling....
Any ideas?
As for what brought this on, well, hard to crank... push-starts just fine... Shorting the solenoid rapidly with a metal stick of sorts tends to get it to start, but only with a charger on "jump" mode.
Battery is new and is rated with plenty of CCA's. Wires for engine ground and battery to starter are new and can handle more than my house can (tripple O) and all the relays and fuses seem to be just fine....
Ignition switch? Perhaps....
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
Re: Wondering what a fuse goes to.... [Re: NCBBA2358] #595100 04/21/05 08:34 PM
BigJim Offline
Howdy Vidette
I understnd the computer uses some v 24/7. Could that be the fuse?
Also the solonoid can be replaced cheaply. Does it bother to "click" when you turn the key? If so the key is not the problem.
Hig Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: Wondering what a fuse goes to.... [Re: BigJim] #595101 04/21/05 10:27 PM
Hig Jim,
HaHa,.,.,.
Well went to NAPA in one town and they said they only offered a 1-year warranty on the starter, went to another NAPA in the other town near here and they offered a lifetime warranty on same part... strange...
Replaced whole starter with it's solenoid and starts fine....
Still have no idea what that 20 amp fuse goes to....
Before, it did click, but wouldn't start, so was most likely a solenoid and not the starter motor.... Under warranty, sortof, and replaced and starts fine....
Still don't know what that fuse is....
Thanks, BJ, any support on this would help!
~NCBBA
Re: Wondering what a fuse goes to.... [Re: NCBBA2358] #595102 04/22/05 02:01 AM
I think big jim's on the right track. I think I.O.D. stands for ignition off d..... something. My .02 <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5974 MB (Peak: 0.6583 MB) Data Comp: Off Server Time: 2026-11-02 08:48:06 UTC
