EGR Hex Bolt?
#595361
04/22/05 05:41 AM
I cleaned the EGR tube the other day and was looking at better way to really clean it thoroughly so I don't need to do so frequently. I noticed there is a hex bolt just below the EGR which seems to plug the end of the EGR tube. I figured I could remove this to gain better access to the tube, but it's stuck. Initially, I was able to move it just a bit but now it's stuck. I've tried when it's been cold and hot to no avail. Any ideas? Is this a reverse threaded bolt?
Any help is appreciated.
For those who wonder why I would need to do this, I talked to an Isuzu mechanic when waiting for an IMG replacement and he said they use some a wire or coat hanger to stick through the butterfly valve and ream out the EGR tube. Then spray the throttle body cleaner and finish with compressed air. I have done this and it seems to work fairly well but I think that it work better if I had access to the tube from the EGR side.
2000 Rodeo LSE
Re: EGR Hex Bolt?
[Re: mr_spicoli]
#595362
04/22/05 06:09 AM
The bolt on the under side of the EGR holding the tube to the valve is a 22mm bolt with a normal thread. just remember you're looking at it from the back of the bolt.
BTW its good to see other Minnesotans on here!
Mike W
Mike Walter '98 Amigo well used '94 Rodeo in need of help '99 Ram CTD for hauling feather pillows '01 unheated shop
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5882 MB (Peak: 0.6368 MB) Data Comp: Off Server Time: 2026-05-29 23:38:23 UTCValid HTML 5 and Valid CSS
