front end vibration? #595487 04/22/05 03:49 PM
Roland2655 Offline OP
Lately I've notice that my 85 pickup vibrates (front end) when taking off from a stop. I have 31x10.5 on the truck and was wondering if this could be part of the problem. I also don't experience shimmy or anything that would suggest the front end is out of alignment at highway speeds. Some of the bushings seem pretty worn out, but no more so than you would expect from a truck this old.
ridge runner
Re: front end vibration? [Re: Roland2655] #595488 04/22/05 04:20 PM
4Crawler Offline
Sounds like worn bushings, etc. The the front tires off the ground and check for excessive play in the spring bushings, the steering linkage, the wheel and knuckle bearings, steering stabilizer, etc.
Re: front end vibration? [Re: 4Crawler] #595489 04/22/05 04:46 PM
thanks 4crawler, pretty much what I thought. Is there any one item that has a history of being a problem?
ridge runner
Re: front end vibration? [Re: Roland2655] #595490 04/22/05 05:13 PM
4Crawler Offline
Pretty much anything can wear out. Spring bushings are common and easy to replace, polyurethane bushings are a good upgrade. Wheel and knuckle bearings can wear out and need replacement. Draglink ends can get worn and lead to play in the steering, etc. I would check everything and fix whatever is shot.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6033 MB (Peak: 0.6589 MB) Data Comp: Off Server Time: 2026-06-20 17:52:31 UTC
