Trooper's 95 vs 96 rear axle assembly #596619 04/25/05 07:14 PM
ehess Offline OP
Anyone know what (if anything) the differences are between the two are? I grenaded the rear end in my '95 troop <img src="/forums/images/graemlins/frown.gif" alt="" /> trying to figure out if '96 will fit. TIA
-Erik
1995 Trooper SOHC, 255/85R16 Dunlop Mud Rovers, OME 912, 2" Daystar coil spacer, torsion bar crank
Tera-Low in the T-case and 5.38's Rear LSD
Re: Trooper's 95 vs 96 rear axle assembly [Re: ehess] #596620 04/25/05 09:35 PM
jezeric Offline
Isuzu Moderator
They should both be Isuzu Corporate 12 Bolt axles with disc brakes. I don't remember off hand which year went to a slightly wider axle, but I'm thinking it was later than '96.
What exactly did you grenade? Potentially, you might be able to pull just the third member and replace that, rather than the entire axle, and that should be the same from one to the other, barring a possible LSD question.
James
Re: Trooper's 95 vs 96 rear axle assembly [Re: jezeric] #596621 04/25/05 10:14 PM
ehess Offline OP
James
I guess some history is in order... about 2 wks ago I chnged diff fluid and found what appeared to be the very tip of a gear tooth and the "normal" very fine metallic powder, I refilled and crossed my fingers, figuring with 110k mi on it and some abuse it was just a fatigue fracture, and crossed my fingers.I don't know what exactly grenaded yet, haven't had time to tear into it <img src="/forums/images/graemlins/frown.gif" alt="" /> left wheel slipping, jerking, crunch bang, under load especially while turning. NO LSD on this truck. On draining the fluid this time found LARGE abount of fine metal powder and bright shiny flakes of metal who knows where from. I was thinking of replacing the whole thing beause I was under the impression that changing the center section required special tools/skills for proper setup. BTW thanks for your quick reply
-Erik
Re: Trooper's 95 vs 96 rear axle assembly [Re: ehess] #596622 04/25/05 10:32 PM
strawmyers Offline
Isuzu Moderator
If you swap in an entire replacement 3rd member, it does not require any special tools. If you put in just a new carrier (like when adding an ARB locker or LSD), then the ring gear must be set up on the new carrier and everything shimmed out... which does require special tools.
From the symptoms you are describing (metal pieces/shavings and trouble turning), it sounds like you may have broken a spider gear.
Sean Strawmyer
Re: Trooper's 95 vs 96 rear axle assembly [Re: ehess] #596623 04/26/05 01:20 AM
W
Wareagle Offline
The '96 and '95 have interchangability. Does your '95 have fender flares? If so, the 95 and 96 axles are the same width. The only differnces could be between ABS possibilits (rear vs 4wheel).
Re: Trooper's 95 vs 96 rear axle assembly [Re: Wareagle] #596624 04/26/05 06:17 PM
ehess Offline OP
I appreciate all the responses I'll update, hopefully with pics, when I tear down and fix it <img src="/forums/images/graemlins/kewl.gif" alt="" />
-Erik
Re: Trooper's 95 vs 96 rear axle assembly [Re: ehess] #596625 04/28/05 06:43 AM
taro Offline
at some point in '97 is when the rear diff changed somehow so the '96 should be okay. i'm not even sure what changed, but for some reason, some '97 diffs can't be fitted with an arb locker.
Re: Trooper's 95 vs 96 rear axle assembly [Re: taro] #596626 04/29/05 01:38 AM
JLEMOND Offline
Sept of 97 was when they changed , after that date they were 98.s and are a lot different . Jerry
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6235 MB (Peak: 0.7226 MB) Data Comp: Off Server Time: 2026-07-14 10:41:48 UTC
